586,060 active members*
4,158 visitors online*
Results 1 to 10 of 10
    Jan 2018
    21
    4 Axis Postprocessor Fusion 360
    Hello Forum, hello Supportteam.
    I use the MK3/4 controller and for drawing and cam Fusion360.
    I got a postprocessor whitch works realy good but i can not use the 4 Axis.
    There is en error when i create the gcode.
    Anybody have an idea or an postrocessor?
    If somebody need, i can upload the pp whitch i use.
    Also i have a second pp without use the G43 gcode.
    It is very helpful for generate without G43.
    Regards from Germany
    Mar 2017
    1312
    Re: 4 Axis Postprocessor Fusion 360
    Which error do you get?
    Jan 2018
    21
    Here is the Errorpost
    Information: Configuration: Planet CNC USB
    Information: Vendor: Planet CNC
    Information: Posting intermediate data to 'U:\Fertige G Codes\Tests\1001.tap'
    Information: Total number of warnings: 1
    Error: Failed to post process. See below for details.
    Loading locale from 'C:\Users\Alex\AppData\Local\Autodesk\webdeploy\pr oduction\72ff341930ac680f0fc073441e10ee045a3f129c\ Applications\CAM360\Data\Translations\german_de.xm l'
    Code page changed to '1252 (ANSI - Lateinisch I)'
    Start time: Saturday, January 06, 2018 8:55:57 PM
    Code page changed to '20127 (US-ASCII)'
    Post processor engine: 4.2.1 41684
    Configuration path: C:\Users\Alex\AppData\Local\Autodesk\webdeploy\pro duction\1c8eda3d042f236f121d6fb4e850f0621b6f700b\A pplications\CAM360\Data\Posts\planetcnc.cps
    Include paths: C:\Users\Alex\AppData\Local\Autodesk\webdeploy\pro duction\1c8eda3d042f236f121d6fb4e850f0621b6f700b\A pplications\CAM360\Data\Posts
    Configuration modification date: Friday, December 30, 2016 10:30:15 AM
    Output path: U:\Fertige G Codes\Tests\1001.tap
    Checksum of intermediate NC data: 25a988730a3aff5a5b45ca592ec9a177
    Checksum of configuration: eb02babaea990edbf614efdf01b66663
    Vendor url: GameSpy: PC Games, Reviews, News, Previews, Demos, Mods & Patches
    Legal: n/a
    Generated by: Fusion 360 CAM 2.0.3797
    Warnung: Work offset has not been specified. Using G54 as WCS.
    Fehler: This post configuration has not been customized for 5-axis simultaneous toolpath.
    Fehler: Failed to execute configuration.
    Stop time: Saturday, January 06, 2018 8:55:57 PM
    Post processing failed.
    Sep 2009
    1856
    That means the A axis and B or C is not turned on in the post processor.
    It's under on open you change it from false to true and set what Axis you wont on extra to a axis
    This is what the code looks like that needs changed
    if (false) {
    var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], cyclic:true, preference:1});
    machineConfiguration = new MachineConfiguration(aAxis);
    http://danielscnc.webs.com/
    being disabled is not a hindrance it gives you attitude
    [SIGPIC][/SIGPIC]
    Jan 2018
    21
    Here is the used Pp
    You have only change ending .txt to .cps
    Attached Files Attached Files
    Sep 2009
    1856
    Done it did it with A and B axis
    [SIGPIC][/SIGPIC]
    Jan 2018
    21
    Awesome.
    What was the reason for the error?
    I try it so soon as possible
    Now i need the new license for TNG Software.
    Yesterday i switched from old version to TNG.
    It`s tricky but slowly it will run.
    Now waiting for the license and then i can try the Pp.
    Thank you Daniel for your Help.
    Best regards from late night germany :-)
    Alex
    Sep 2009
    1856
    What was the reason for the error? The A axis was set to be off in the post it's the way most posts are that it's off by default and I added the B axis for fun, if you needed it, it cab=n be changed to c easyily.
    [SIGPIC][/SIGPIC]
    Jan 2018
    21
    Dear Daniel.
    The change in Pp works awesome.
    Thank you.
    Now i can use the 4th rotaryaxis :wee:
    Sep 2009
    1856
    Good stuff thanks for the confirmation that it works.
    [SIGPIC][/SIGPIC]
  1. 4th Axis and Fusion 360
    By mattford1 in forum Tormach Personal CNC Mill
    Last Post: 11-28-2016, 07:24 PM
  2. Solidcam five axis postprocessor editing (by modifiying 3 axis post)
    By allenp in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-19-2016, 03:16 PM
  3. CNC Fusion Z Axis Question
    By cadguy247 in forum Benchtop Machines
    Last Post: 12-04-2014, 05:33 PM
  4. CNC Fusion X2 kit - possible to swap over X-axis?
    By Steoh in forum Benchtop Machines
    Last Post: 02-18-2011, 01:15 AM
  5. X2 CNC Fusion #4 Kit Y-axis Mod
    Last Post: 01-08-2011, 09:29 PM
