586,219 active members*
3,336 visitors online*
    Jan 2014
    19
    ATC not working...........
    the ATC isn't going to the load position...? When I click on pathpilot in the ATC go to load position, all I hear is air coming out of the brass bleeder valves..? I've taken the valve apart and with a little air operated the ATC. So I'm not sure if the solenoid isn't working the plunger tube at transfers the air.?
    Nov 2011
    26
    Re: ATC not working...........
    not sure which machine you are on but can you turn the small screw of the valve body to see if that will send and lock it in Tray Load position?
  1. Setting drills, ID tools and back working/end working tools
    By jonathan2jones in forum CNC Swiss Screw Machines
    Last Post: 04-22-2017, 01:11 AM
  2. What is the difference between wood working and metal working routers?
    By LaughingJaguar in forum Joes CNC Model 2006
    Last Post: 10-17-2016, 07:29 PM
  3. Switch view between machine working enveloppe and job not working?
    By skillalot in forum Screen Layouts, Post Processors & Misc
    Last Post: 08-10-2015, 03:55 PM
  4. CNC NOT WORKING
    By enigma1946 in forum Mach Software (ArtSoft software)
    Last Post: 05-16-2013, 03:53 PM
  5. Working with DWG's in MC X3
    By jewells in forum Mastercam
    Last Post: 09-03-2009, 03:32 PM
