586,069 active members*
3,456 visitors online*
Results 1 to 6 of 6
    Jul 2016
    15
    Multi Start threads
    Is it possible to do multi start threads on this machine?
    I use fusion 360 and not having much luck and wanted to make sure its even possible.
    May 2008
    667
    Re: Multi Start threads
    I have no idea but, I would try to change the Z start with half the TPI for the second pass, again, I have no idea as I never tried this.
    Jeff
    Feb 2011
    353
    if you can single point thread on your machine you would be able to do multistart threads
    a two thread lead you would position the start point pitch/2
    Jul 2016
    15
    Jeffery
    Would there be some calculation as to how far to start out the Z?
    Rcs60
    So I start the 1st thread at whatever is regular then the 2nd pass at pitch/2?
    Or both pitch /2 but offset somehow?
    Feb 2011
    353
    the first tread would be normally how you set up your threading
    second thread lead start would be previous start + 1/2 pitch
    20 tpi thread 2 lead start
    ex. first thread start at .100
    second start would be .100+.[.100/2]=.150
    most multi-lead threads are spec'ed out at the threads per inch so that a 1/2-20 thread would have 2-10tpi threads with the pitch the equivocal of a 20tpi thread
    Jul 2016
    15
    Thanks took me a minute to figure out.
    Threads per inch / 2 then the pitch of that thread / 2 + start.
    This is just something I'm messing with myself no real design going off.
  1. SW can't do multi-start acme threads?
    By Species8472 in forum Solidworks
    Last Post: 07-01-2011, 09:09 PM
  2. ACME rods - normal start and multi-start
    By shaffin in forum Canadian Club House
    Last Post: 12-20-2010, 02:19 PM
  3. Using "Q" on G32 for multi start threads
    By Species8472 in forum GibbsCAM
    Last Post: 12-29-2008, 03:17 PM
  4. THREE START THREADS
    By ENSHU in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-25-2008, 03:46 PM
  5. Multi start threads
    By naytep in forum GibbsCAM
    Last Post: 09-06-2007, 01:28 PM
