586,060 active members*
3,555 visitors online*
Thread: Dual 203v
    Feb 2005
    117
    Dual 203v
    My question is can I use 2 Gecko drives to run 2 motors on one axis. I was planning on using the step and
    direction signal from the breakout board for that axis feeding both drives.
    Application is for a large 3d printer.
    Jan 2007
    467
    Re: Dual 203v
    johnd,
    Sorry for the delay in getting back to you. Yes, you can run two motors on a single axis and they can both be fed the same STEP and DIRECTION signals. If the motors are facing each other they will need to mirror the movements, so just swap A and /A on one of the drives and it will move in the opposite direction of the other motor.
    Marcus Freimanis
    www.geckodrive.com
  1. selling dual head camfive CFL-CMA1390kt dual head machine
    By relivegreen in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-24-2016, 08:11 PM
  2. Replies: 0
    Last Post: 07-02-2016, 10:28 PM
  3. Dual Steppers or Timing Belt for Dual X-axis?
    By GEBrown in forum Linear and Rotary Motion
    Last Post: 05-27-2010, 05:45 PM
  4. Difference between 201, 202, and 203V??
    By flash319 in forum Gecko Drives
    Last Post: 04-21-2009, 01:44 AM
  5. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 09:15 PM
