586,080 active members*
3,563 visitors online*
Results 1 to 8 of 8
    Sep 2017
    12
    Plasma - Magnetic Breakaway Mach3 Settings
    I'm currently putting together a plasma machine, and we're including a magnetic breakaway to protect the torch. Machine is run off a laptop running Mach3, using a USB Smoothstepper.
    This is my first time including a magnetic breakaway. I originally thought to program it as an e-stop in the Mach3 Pins & Ports/Input signals. Or is there another common way to set up the breakaway? It is simply a Normally Closed switch that activates when the torch holder breaks off.
    Appreciate any input.
    Jul 2016
    660
    Re: Plasma - Magnetic Breakaway Mach3 Settings
    Are you triggering your plasma torch manually? because in a typical CNC plasma machine it will plunge on the material then there`s some magnetic switches to activate when the torch holder with springs gets lifted, then it backs up (torch height controller) then triggers the plasma machine then fine tunes the height to it`s optimum amperage (amp sensor in the plasma machine in conjunction with the torch height controller module) on the plasma machine then that`s the time it will move to the program path.
    Sep 2017
    12
    We're using Ohmic sensing for initial height sense. I used to use floating head, but decided to move to Ohmic.
    But I don't see how this affects the magnetic breakaway. This is just as a safety mechanism, which must switch off the machine when the switch is activated (torch breaks away when it hits an object).
    Apr 2003
    540
    A separate switch on the breakaway mount is simply a switch wired to your e-stop circuit. As long as it triggers when your torch mount plates are separated Should be pretty easy to figure out using a ordinary micro switch wired to N/C. It sounds like Mach is firing your torch after a height set macro (in sheetcam?) and then turning it off after each cut etc. Your emergency stop should be set up in Mach to also shut off your torch anyway as a safety precaution
    Sep 2017
    12
    Thanks coherent, that's exactly what I was considering, setting it up as an e-stop.
    Apr 2006
    54
    Hello,
    You can also look our page at AGELKOM News Page for TORCH PROTECTOR. Vertical mount is not worked properly.
    Sep 2005
    287
    Quote Originally Posted by agelkom View Post
    Hello,
    I think you need to explain what you mean by, "Vertical mount is not worked properly". There are many designs of breakaway out there and most of them appear to be vertical mount style.
    Nobody seems to be complaining that their breakaways are not working. Quite the opposite really, most users say their breakaways have saved the torch a few times.
    Apr 2006
    54
    Vertical mounting works naturally, but we saw that vertical assembly did not work as expected in our experiments, torch nozzle was a little crushed. We had to experiment more to optimize, then we tried horizontal protection and it was fast and easy to adjust, magnetic field intensity and return to original position.
  1. Replies: 0
    Last Post: 10-28-2015, 10:58 PM
  2. Universal CNC plasma breakaway mount from Snap 'n Cut
    By Benderart in forum News Announcements
    Last Post: 05-28-2012, 06:36 AM
  3. Magnetic machine torch breakaway mount for DHC2
    By Benderart in forum PlasmaCam
    Last Post: 12-14-2010, 11:33 PM
  4. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
  5. constant velocity and power settings in mach3 plasma cutting
    By Knut in forum Waterjet General Topics
    Last Post: 09-28-2006, 04:19 AM
