586,115 active members*
3,432 visitors online*
Page 2 of 2 12
Results 21 to 27 of 27
  1. #21
    Apr 2013
    1899
    Re: Fried a power supply
    The fuse is only for the main input power supply 120v / 240v Ac there is no protection on the DC side of these power supplies
    I see... not the way I'd design it...
  2. #22
    Apr 2013
    1899
    Quote Originally Posted by rotccapt View Post
    Thank you for the info, I'm going to build the circuit I posted and am looking at switching the 5v control. If I can't do that I will move my relay to the DC side between the ps and the protection circuit
    Why not start with building an analogue PSU instead? All it needs is a transformer, a rectifier and a large capacitor. You are much better off with that than using a switching PSU + your circuit.
  3. #23
    May 2012
    40
    Main reason is my motor speed control can only take up to 25v, I have not looked but I know a 24v ac transformer will produce close to 30v dc, I also already have the ps
  4. #24
    Mar 2007
    2083
    I take the 25V limit is because the speed control is designed to be powered by 6 Lithium polymer cells
    that can absorb any returned energy (unlike the 24V switch mode power supply)
    if you protect the power supply with a diode
    I expect the speed control will be at more risque unless you add a shunt stabiliser / returned energy dump across the speed controls supply terminals
    without a circuit diagram or speed control board to study is impossible to tell how high a supply voltage the board can survive
    unless the speed control came with detailed specifications
    John
  5. #25
    May 2012
    40
    You are correct about the voltage limit. I do not have any detailed info on the speed control. It is rated at 80A and can handle 1 to 6 lipo cells
  6. #26
    Apr 2013
    1899
    OK, in that case I'd add a simple voltage regulator circuit or would chose a transformer suitable for the purpose. You don't need to buy one with 24VAC secondary... 18VAC is pretty common. But sure, since you already have a PSU you might as well use that one until it lasts or you get tired of the fan noise, assuming it has a fan.
  7. #27
    Dec 2005
    160
    2 MOV's rated at 160 joules 36vdc
    each and a large filter cap as his motor is pulling about 200w
Page 2 of 2 12
  1. Replies: 1
    Last Post: 01-12-2017, 07:12 AM
  2. Rapid Loss of Cutting Power- New Tube, Fairly New Power Supply
    By scrappyjedi in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 02-23-2016, 01:24 AM
  3. Replies: 15
    Last Post: 10-29-2013, 12:58 AM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
