586,071 active members*
3,900 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > mach3 steps per calculation
Results 1 to 7 of 7
    Dec 2011
    45
    I thought I had this figured out but since I just switched to 8x microstepping my parts are coming out marginally smaller than they should be.
    200 step/rev steppers.
    10mm pitch ballscrews.
    I had calculated 4064 steps per inch at 8x microstepping (1600 steps/rev)
    is this correct or probably not? I can't math. :tired:
    Apr 2004
    5737
    Re: mach3 steps per calculation
    I get the same number, but there might be something else causing your parts to come out undersized. Are you sure the tool is really the size you're assuming it is, not slightly fatter? Are you accounting for backlash? Are you using your CAM program correctly, cutting to the outside of the part boundary and not on the line or inside it?
    Andrew Werby
    Website
    Dec 2011
    45
    Unhappy Re: mach3 steps per calculation
    Quote Originally Posted by awerby View Post
    I have a theory that my end mill is bent right now I sorta crashed it. It's cutting terribly now for sure. It's supposedly carbide so I don't think those bend they usually just snap but I stopped it just as it was crashing so it may be possible. I just went and bought a new one just in case so I'll try that.
    As far as the steps per goes. The accepted inch to mm conversion is 25.4 but if you look up the long version of that there's a few more decimal spots. Actually converts to 4064.016 steps per rev in my case. That should be completely insignificant. But it is possible over a large distance it could start throwing things off a thousandth or so.
    I guess I'll have to change mach3 to work with mm and just put in 160 steps per mm. But dang do I hate the DRO's reading out in mm
    That's .00025" in 5 ft. or .001 in 20ft
    You're also assuming that your screws are exactly 10mm pitch. The pitch can be off by roughly ±.002" per foot, which is the manufacturing tolerance.
    There's absolutely no reason at all to do this. It has nothing to do with your part sizes.
    If you do some testing, you'll find that part size will change depending on the direction you are cutting. There are many factors that can affect actual part size.
    Feb 2007
    4553
    What actually is marginally smaller? Please post intended dimensions and completed machined dimensions.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Apr 2004
    5737
    If your carbide endmill is behaving as if it were bent (you're right - they don't bend), chances are it's not seated in the collet correctly, which would account for undersized parts (and bad cutting action). If you're using an ER collet system, the collet has to snap into the closer nut before inserting the tool. If you're using a Jacobs chuck to hold the endmill, that could have a similar effect - switch to collets.
    Andrew Werby
    Website
    Dec 2011
    45
    I found my problem.
    Attachment 383596
    That's a new bit I just got yesterday. MDF did that....Bosch sucks.
  1. Mach3 - BOB - Loosing steps
    By twilliamson in forum Mach Software (ArtSoft software)
    Last Post: 08-19-2017, 04:08 PM
  2. Mach3 Step per calculation for CNCRP Pro
    By Blisswoodshop in forum Avid CNC
    Last Post: 04-07-2017, 04:46 PM
  3. Help for calculation of steps per MM.
    By crimar in forum Mechanical Calculations/Engineering Design
    Last Post: 01-11-2014, 06:55 PM
  4. Steps per in mach3?
    By mw29715 in forum Mach Software (ArtSoft software)
    Last Post: 06-25-2011, 08:49 AM
  5. Losing steps with Mach3
    By CMPM in forum Mach Plasma / Laser
    Last Post: 07-20-2007, 04:02 PM
