586,067 active members*
5,272 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Running carbide end mill slower than specified because of spindle speed limit ?
    Aug 2015
    14
    Wink Running carbide end mill slower than specified because of spindle speed limit ?
    Hi again,
    I'm making some metal parts for a roof frame in some C45 steel (1.0503 (EN) Medium-carbon Steel)
    For the moment I'm doing the first operation (exterior contouring) on a kind of M14 tie rod part using a 12mm LMT-FETTE DHC Premium end Mill with Ae = 2mm and Ap = 20mm.
    The specs for these mill for C45 is 230 to 275 m/min cutting speed (so using 12 mm diameter and 4 flutes we get a RPM range of 6101 to 7295) and a chip load per tooth of 0.14 mm/tooth which gives us a feed range of 3417 to 4085 mm/min (135 to 160 IPM)
    I'm running at 6000 RPM (my HAAS mini mill 2 maximum spindle speed, alas....) at 1500 mm/min (60 IPM)
    Yes the Feed is SLOW... barely 47 cc/min (2.9 cubic inch/min) chip load per tooth is a mere 0.05 mm/tooth, I'm running way slower because I'm trying to keep my spindle load meter around 85% (7.5 kW HAAS spindle.... :bs: ) and I'm not in any hurry (cycle time is 4 minutes, it takes longer just to set up each part in the vice...) and after 1 hour of cutting time the spindle load has only gone up 2% so wear seem to be very low
    The thing is in operation step 3 I'm going to have to slot these parts making a 11 mm wide 39 mm deep slot, I plan on doing this with a first "old style" 10mm wide slotting operation using a 10mm LMT-FETTE DHC Premium end Mill, taking 3 mm off at each pass... and a final full depth contouring to 11 mm wide with a carbide TIALN end mill problem being that using my maximum spindle speed of 6000 RPM I can only get 189 m/min on the cutting speed... (ie 80% of the minimum recommended speed)
    How does this affect the performance , should I dial down on the chip load ?
    Oct 2011
    106
    Re: Running carbide end mill slower than specified because of spindle speed limit ?
    I would just work out from your chip load what you feed needs to be with your slower spindle speed. I always use the same feed per tooth whatever spindle speed I’m able to achieve.
    Apr 2005
    713
    Do the math on a .010" endmill at 12,000 RPM. Far from ideal in any material, but we do it on a regular basis with good success. Sometimes in extreme cases you have to back the feedrate down a little because such low SFM compromises the shearing action of the tool to the point that it will fail at "normal" chip loads. You are nowhere near that.
  1. RPM is running much slower then inputed rpm
    By TheGreenMachine in forum Fadal
    Last Post: 05-25-2021, 11:17 PM
  2. Mach3 - Homing speed much much slower than jog speed
    By SouthPark in forum Mach Software (ArtSoft software)
    Last Post: 01-23-2017, 04:46 PM
  3. mach3 spindle dro not working, spindle speed changing while jogging and running code
    By jasminder in forum Mach Software (ArtSoft software)
    Last Post: 02-23-2011, 07:12 AM
  4. Running carbide end mills in side-lock end mill holders
    By Cory in forum MetalWork Discussion
    Last Post: 01-14-2008, 02:55 PM
  5. help with speed and feed carbide end mill
    By alex 850 in forum Bridgeport / Hardinge Mills
    Last Post: 12-27-2007, 06:10 AM
