586,075 active members*
4,167 visitors online*
Page 2 of 2 12
Results 21 to 28 of 28
  1. #21
    Aug 2012
    279
    Re: Shaped sheet metal punch
    Found a deal on 1/2" 4140 HRHT but it is 24 x 58 inches! I am going to see if they have a way to cut it down - maybe two strips 12 x 58. I think I could find a horizontal bandsaw with 12" cut. Or maybe several 12 x 24 chunks. Don't think I want to torch or plasma cut it - won't that make the edge harder? Maybe not if it is already HT so perhaps crack it... Could get it onto a mill table and mill it into pieces. Don't know of anything else that will work reasonably well... Ideas?
  2. #22
    Dec 2013
    5717
    In my shop I would use my vertical band saw or my Evolution saw to cut into bite sized pieces. Water jet cutting would be good option, in fact, I would be tempted to have the pieces roughed out with a water jet, then finish on the mill.
    Jim Dawson
    Sandy, Oregon, USA
  3. #23
    Aug 2012
    279
    I checked around on the cost of water jet. there is a maker space here that has one but with membership and training I am at about $350 before I start. Machine time is pretty cheap after that. But the large CNC mill I need for the size parts I am doing is at another one. They have a cnc plasma table - not sure if it can handle 24" wide plate. From what I have read the plasma cut only affects the steel to a very shallow depth so if I just just the outside of plates it won't be a final working surface and can be ground off if I need to machine but could likely just leave the outside as is on many parts. My machinist friend said they have a water jet and that the cutting might run a couple hundred dollars which doesn't sound too bad, especially if they can do some of the other cutting at the same time. I might be able to get into the college where I took a class and use their horizontal band saw that has coolant and adjustable speed - not sure if it can handle 24" cut.
  4. #24
    Aug 2012
    279
    Just got back a quote on 4140 HT 1/2 x 12 x 12 plate decarb free at $157 each. For 4 plates from another source 4140 annealed same size was about $525. The HRHT 1/2 x 24 x 58 is about $250. Seeing that I need a number of pieces it seems like figuring out some way to deal with the large sheet would be the way to go.
  5. #25
    Aug 2012
    279
    Having a hard time finding a horizontal bandsaw big enough (24.5") and can't imagine trying to get through 24" several times on a vertical bandsaw while wrestling a 200+ lb plate. Would plasma cutter be a reasonable way to cut this 4140 HT plate? I have access to a CNC plasma table. I know it would mess with the hardness but from what I have read that is very thin (around 0.01") and could be ground off if if was too difficult to mill. I don't need the perimeter of the plates to be the working edge on most of the parts so could leave as is at least for some.
  6. #26
    Aug 2012
    279
    I like carbide tipped reamers, a little more forgiving than solid carbide reamers. In most cases, I drill and ream in one setup.
    I take it carbide tipped reamers can take a bit more flex in the shaft so are less likely to break the shaft - is that the main benefit of carbide tipped? In sizes around 1/4" carbide tipped are about $47 and solid carbide are about $10 less so not a huge difference. I also see that the shanks are 15/64 which will not work well in a R8 1/4" collet (and not wanting to go to ER32 collets which would have enough range to properly grip them). Planning to use them in a drill chuck. I realize it isn't quite as good as a collet but is this any real issue? I will be using the drill chuck for the drilling so it's an easy change out to the reamer.
  7. #27
    Dec 2013
    5717
    Quote Originally Posted by Jim27 View Post
    The only problem with plasma is the edge hardening. If you can work around that, then you should be fine. Water jet would be my first choice if available.
    That's odd, normally solid carbide is more expensive than carbide tipped. But yes, the shank is more flexible on the carbide tipped and they should follow the hole better. The main reason i use carbide tipped is that they are longer lasting than HSS reamers without much price increase. I don't think I have any solid carbide reamers. I do 90% of my reaming using a drill chuck.
    Jim Dawson
    Sandy, Oregon, USA
  8. #28
    Aug 2012
    279
    Was just talking to someone at work about a shop nearby with a waterjet that should give me a good deal on cutting this up into manageable pieces. Will keep the plasma in mind as a backup....
    I was surprised solid carbide was cheaper too. I have a few HSS reamers that were a little less than half the cost of carbide but I can see that if they get much use the carbide is longer life and will save money in the long run.
Page 2 of 2 12
  1. Suggestions for making blanking die and punch for thin copper sheet
    By JetForMe in forum Diemaking / Diecutting
    Last Post: 07-06-2016, 02:16 AM
  2. Metal laser cutting machine is easier to achieve diversification sheet metal
    By mornlaser2014 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-16-2014, 07:46 AM
  3. Replies: 6
    Last Post: 10-05-2013, 03:40 AM
  4. Need name of X-Shaped Metal Bars
    By ignisuti in forum MetalWork Discussion
    Last Post: 10-22-2009, 06:21 PM
  5. Sheet Metal Work - Punch / Laser
    By Mark Green in forum Uncategorised MetalWorking Machines
    Last Post: 01-30-2009, 02:52 AM
