586,567 active members*
3,668 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Wanted guidance on DIY CNC machine for wood works/carving
    Jan 2018
    Hello All
    I am newbie.Wanted guidance on selection of DIY CNC machine for wood work/wood carving.Thanks
    Re: Wanted guidance on DIY CNC machine for wood works/carving
    For your consideration: https://hobbycnc.com/product/diy-cnc-router-plans/
    Regards, BrianV
    WoodWorkerB
    HobbyCNC.com, WoodWorkerB.com
    Jan 2018
    Thanks a lot any with free plans and suggestion of one to go in..Was searching like OX and viscous cnc also has pls suggest the one that is easy and overall more performance rich
    May 2005
    3920
    Quote Originally Posted by aruneshdutta View Post
    Hello All
    YOU really need to define what you want before anybody can really help you here. Wood work encompasses a wide array of activities some requiring far better performance than others. Like wood carving can mean different things to different people, for one it might mean cutting a carving into 5/4 that isn't any deeper that 3/8 or an inch.for another it might mean using a 4th axis to do a 3D carving on a 15in diameter work piece.
    In other words the work intended defines the machine. You can easily spend $5000 or $50,000 and not be happy with the machine you purchased if it is the wrong machine for your intended usage. Right now there is little that anybody can comment on.
  1. Suggestions when you buy an ATC wood carving machine
    By RoseChina in forum News Announcements
    Last Post: 03-05-2015, 04:10 AM
  2. We have new CNC Wood Carving Machine Updated
    By Baiansy in forum Roctech CNC Routers
    Last Post: 11-27-2014, 06:17 AM
