586,067 active members*
5,085 visitors online*
Results 1 to 7 of 7
    Feb 2005
    111
    inputs outputs
    I first had my main computer setup running mach 3. My computer using xp pro. Now I put my cnc in the garage and bought a laptop for it using a wireless router. My laptop is running 2000 professional. Now none of my exact settings will work with the cnc ???
    Are you sure the laptop is capable of running Mach3?
    Feb 2005
    111
    The laptop is a dell 1ghz and 256mb of ram. Running 2000 pro. Why wouldnt it be capable of running mach 3?
    Mar 2004
    761
    Check the BIOS setting of the parallel port.
    Wayne Hill
    Run the drivertest.exe in the Mach3 folder. Make sure it gives good results. Lots of laptops won't run well, for a variety of reasons. Power management being one reason, 3.3V parallel ports being another.
    Feb 2005
    111
    ok I dont have a problem switching out computers, I just thought being mobile would be the way to go out in my garage. I didnt realize problems like that existed. Let me swap out computers and I will let you guys know.
    Feb 2005
    111
    I can still get movement and everything but the settings I put such as my inputs to make motors turn in correct direction are messed up and only wants to go in one direction
  1. E-stop and enable outputs
    By Drew in forum Machines running Mach Software
    Last Post: 06-01-2009, 12:18 PM
  2. Inputs/Outputs
    By UKRobotics in forum CNC Machine Related Electronics
    Last Post: 08-03-2006, 03:52 AM
  3. Opto 22 / ICM outputs not working
    By mzartop6 in forum CamSoft Products
    Last Post: 01-28-2006, 05:35 AM
  4. R20x0 encoder outputs?
    By mecheng10 in forum Servo Drives
    Last Post: 10-06-2005, 03:11 AM
  5. Encoder output into 2 different inputs?
    By murphy625 in forum Servo Motors / Drives
    Last Post: 03-23-2005, 04:36 PM
