586,116 active members*
3,346 visitors online*
Results 1 to 9 of 9
    Need Some Breakout Board Upgrade Advice
    Hey Everyone!
    I'm looking for advice or pointed in the right direction. I'm a newbie to CNC, but I really want to learn, so I recently bought a 2012ish Velox VR-5050 CNC Router from the company I work for. It has been sitting for the past few years and when I powered it on & tried to jog it nothing happened. It's an older parallel port setup and on the back of the control box shows green lights lit next to the Estop, A Axis & parallel port, but no lights lit next to the X, Y & Z axis. I've attached some pics. It's 3 axis with 4 motors.
    Velox said the breakout board &/or the drivers probably need replacing, but they've been a bit unresponsive since their quote...
    So anyway my question is:
    1. Is now a good opportunity to upgrade to a 4axis USB or Ethernet motion controller?
    2. Is that even possible with a bit of rewiring?
    3. Would an Azteeg X5 GT 32bit Motion Controller with Bigfoot BSD2660 SPI drivers do the trick? https://www.panucatt.com/mobile/prod...r_p/ax5gt.htm=
    Any help is greatly appreciated, thanks!! Sorry for the long message
    Attached Thumbnails Attached Thumbnails powered with drivers in.jpg   unplugged with drivers out.jpg   back of box.jpg   drivers.jpg
    Jul 2016
    660
    Re: Need Some Breakout Board Upgrade Advice
    You need to configure your LPT1 port first in your PC BIOS, also in the device manager you need to make sure there is an LPT1 port detected, that motion card is widely used for mass production, it`s a rock solid stable board, and can almost last a lifetime.
    Those look like Gecko G251 drives, with a custom board.
    The G251's are far better drives than the ones you are looking at, and are most likely just fine.
    Did the machine come with the PC running Mach3? If so, chances are, as the previous post said, just a configuration issue.
    Quote Originally Posted by KH0UJ View Post
    Hey KH0UJ,
    Thanks for the reply! My brother is the IT server building guy so he will be handling the BIOS stuff Just to be clear, do you mean the original card that it came with is rock solid?
    Hey ger21, thanks for the help!
    They are Gecko something's for sure It's the original computer, but the guy couldn't remember the password, so I had to factory reset & reinstall windows 7 that was on it and reinstall Mach 3 from the disc that was in a binder from Velox. He also didn't have the serial/registration license for Mach 3 anymore so it's just in Demo Version mode.
    So if it's not configured correctly, then it could make sense that those axis lights are off?
    Yes. You have to go through all of the configurations before it will work. Also, it has to be a 32 bit version of Windows 7.
    Wow, Velox just replied saying "We actually have the license and profile for this machine in our archives, so I've attached them to this message..." at the same time you guys were helping, so I'll give that a shot for now.
    Thanks so much for your help, I really appreciate it! ...and I'm already learning:wee:
    Sep 2019
    Quote Originally Posted by simonfisher View Post
    Wow, Velox just replied saying "[FONT="]We actually have the [/FONT]license and profile for this machine in our archives, so I've attached them to this message..."
    I happen to have the same problem, picked up a vr-5050 with no computer. The customer service tech wasn't very helpful . Would you be willing to share the config profile for Mach3? I'm attempting to setup all the pinouts manually and that would help a lot. Right now I'm worrying about selecting the wrong pin and jogging an axis too far.
    Sep 2019
    If anyone else comes across this post with the same issue here are the pinouts.
    Parallel Port
    01 - Relay 1
    02 - Step X
    03 - Direction X
    04 - Step Y
    05 - Direction Y
    06 - Step Z
    07 - Direction Z
    08 - Step A
    09 - Direction A
    10 - Switch X
    11 - Switch Y
    12 - Switch Z
    13 - Switch A
    14 - Touch
    15 - Emergency Stop
    16 - Relay 2
    17 - Charge Pump
    18 - GND
    19 - GND
    20 - GND
    21 - GND
    22 - GND
    23 - GND
    24 - GND
    25 - GND
  1. Advice please Setup Breakout board and Smooth Stepper
    By NormanA in forum SmoothStepper Motion Control
    Last Post: 05-02-2017, 09:26 PM
  2. Help deciding which breakout board or driver board etc to use!
    By localbroadcast in forum Servo Motors / Drives
    Last Post: 06-09-2016, 09:25 PM
  3. Need help, Mach 3 breakout board upgrade!!
    By Wgarner1414 in forum CNC Machine Related Electronics
    Last Post: 05-03-2016, 05:58 PM
  4. Replies: 0
    Last Post: 02-03-2016, 07:20 AM
  5. BREAKOUT BOARD INTERFACE BUFFER BOARD
    By deslee in forum Servo Motors / Drives
    Last Post: 08-17-2014, 07:32 PM
