586,838 active members*
2,560 visitors online*
Results 1 to 10 of 10
    Dec 2017
    4
    A question about speed codes
    Hello,
    I have a cnc wood lathe and currently I only use g-code to program it, which is enough since I only produce simple things. The problem is that I cannot control acceleration or deceleration of the axes' movements. For example I want the Z axis start at a certain speed (say F15000) and I want it to slow down until F5000 when it moves 800 mm away. I read somewhere about this and it says we just write the speed code at the end of the line where we specify the end point as coordinates; for instance G01 F15000 / G01 Z825 X-110 F5000 (slash stands for next line). Supposedly it starts at F15000 and it is at Z70 X-80 for example, and it becomes F5000 when came to Z825 X-110. But this doesn't work! It just perceives the F code at the end of the last line as the speed of the whole movement. So I couldn't manage to observe any acceleration or deceleration that way.
    Anybody has any knowledge about this and a suggestion? Even if you have any idea, please tell, I most probably need it!
    Feb 2006
    1792
    Re: A question about speed codes
    As far as I know, continuous change if feedrate is not possible. It can be changed in steps.
    Dec 2017
    4
    Quote Originally Posted by sinha_nsit View Post
    By steps you mean each code line?
    Feb 2006
    1792
    Quote Originally Posted by Pampop34 View Post
    Yes
    Sep 2002
    1959
    It depends on the controller you are using.
    There are controllers which support this feature and there are others which don't.
    Jan 2010
    171
    Im thinking a macro would help you here if there aren't any other functions, i have a simple program you can try, might need to adjust it for your machine and function.
    (A=#1 NUMBER OF STEPS)
    (Z=#26 Z DISTANCE TO GO)
    (X=#24 X DISTANCE TO GO)
    #104=#5003 (CURRENT Z)
    #105=#5001 (CURRENT X)
    #106=#4109 (CURRENT F)
    #101=ABS[[#26-#5003]/#1] (Z MOVEMENT FOR EACH STEP)
    #102=ABS[[#24-#5001]/#1] (X MOVEMENT FOR EACH STEP)
    #103=ABS[[#9-#4109]/#1] (F CHANGE FOR EACH STEP)
    N1
    WHILE [#104 GE #26] DO1
    #104=#104-#101
    #105=#105-#102
    #106=#106-#103
    IF [#104 LT #26] THEN GOTO9999 (SAFETY CHECK)
    IF [#105 LT #24] THEN GOTO9999 (SAFETY CHECK)
    G1Z#104 X#105 F#106
    END1
    N9999
    M99
    Dec 2017
    4
    Quote Originally Posted by CNCFr View Post
    I am using Mach3 software on my PC, if it is what you mean as controller. If so, does it support this feature?
    Dec 2017
    4
    Quote Originally Posted by ProToZyKo View Post
    N1
    #104=#104-#101
    #105=#105-#102
    #106=#106-#103
    G1Z#104 X#105 F#106
    END1
    N9999
    M99
    Thanks for this. But I don't know anything about what this is. Is it another type of code for CNC like g-code?
    Jan 2010
    171
    A macro is a routine or sub-program that includes non-G-code commands. It is typically used for common operations that will be called many times in a program.
    So the program works like a sub program, so put that in program O8000 or something then change G01 Z825 X-110 F5000 to G65 P8000 Z825 X-110 F5000 A1000(this value can be bigger og smaller depends on how often you want the feed to change)
    35538
    Mach3 does not support If...Then and While in g-code.
  1. Chiron FZ12W High speed Siemens 810m error codes
    By efret in forum SIEMENS -> Sinumerik 810M/810T
    Last Post: 10-15-2022, 08:36 PM
  2. Absolute Newbie Question on G-Codes
    By smokediver576 in forum Tormach PathPilot™
    Last Post: 07-15-2015, 11:44 AM
  3. Have question on several G codes
    By colby2000 in forum CNC Swiss Screw Machines
    Last Post: 09-28-2013, 03:10 PM
  4. NH4000 DCG only uses M speed codes on
    By guitarzycki in forum Mori Seiki Mills
    Last Post: 09-20-2010, 05:39 PM
  5. Spare M Codes Question?
    By AMCTony in forum Haas Lathes
    Last Post: 09-14-2007, 03:59 AM
