586,416 active members*
3,838 visitors online*
Results 1 to 3 of 3
    98
    Gantry Home and Squaring Limits
    Hello...I have a controller that uses a single plug for all limit switches. Standard small headphone size plugin. I wired the 2 gantry limits in series as shown. I only have these 2 so far. I thought somehow Mach3 would be able to square the gantry. Today when it hits one switch it stops. and that is it.
    How do I get the gantry to move both sides (Y & B) independently with the Homing function button? Am I missing another Mach3 setting somewhere?
    Any thoughts appreciated...
    35538
    Re: Gantry Home and Squaring Limits
    The master and slave switches need to be on different inputs, so they can't be wired together.
    And in Config>General Config, make sure "Home Slave with Master" is NOT checked.
    98
    Thank you...sorry for delay in answering...forum access glitch with changing e-mail address.
    I have read different accounts as to how this works and assumed as much but also thought with my limited electrical knowledge I was just misinterpreting the options. I will work on this. Thanks again...
  1. Squaring the x axis gantry
    By Kris-K2 in forum Commercial CNC Wood Routers
    Last Post: 11-26-2017, 01:36 PM
  2. Squaring the Gantry to the X-axis
    By expo123 in forum Avid CNC
    Last Post: 11-09-2013, 01:25 PM
  3. Setting up Config >Homing/Limits Dialog (Motor Home/Soft Limits)
    By CStevens6 in forum Mach Software (ArtSoft software)
    Last Post: 07-18-2013, 04:19 AM
  4. Squaring a gantry - without a square?
    By Instance in forum DIY CNC Router Table Machines
    Last Post: 01-20-2011, 09:37 AM
  5. Squaring the gantry
    By bradbergemann in forum Excitech routers
    Last Post: 01-07-2010, 02:31 PM
