586,077 active members*
3,688 visitors online*
    Dec 2005
    29
    Design question
    Hey folks,
    Couple questions about design for those who know this stuff a bit better.
    Still in the design phases of a 12x12x4" moving gantry router, HSS construction (Its what I know, have and am comfortable working with). Main goals were to cut acrylic and thermoplastics with the occasional piece of aluminum.
    Not enough room (or budget right now) for 2 machines so ...
    1. What design considerations would I need to make - if I realized I'm going to want to mill the occasional piece of steel (ie cutting adapter plate out of 1/2" x 6" flatbar)? Strength I'm not too concerned with - I think I'm well beyond beefy enough...
    2. Can smaller milling projects be done without liquid cooling - or should I start investigting how I can add that? Having a perfect finish isn't needed - mostly just need a decent cut (about equivalent to what I'm getting now using a 4 1/2" grinder and a drill press to make the same components free hand)
    3. I was planning to use a laminate cutter, is there something more appropriate in terms of being able to cut both acrylic - and steel, where the motor speed is variable enough to handle both with enough torque on the low end for the steel?
    4. Is there a recommended 'off the shelf' tool that could be used for steel I've spied some that look like grinders but with a vertical chuck in the mill forum - but no clue what they'd be called/where to source them. That's assuming I needed to use two different tools and swap as needed.
    Any thoughts/advice would be appreciated
    I think you'd need 2 different spindles, one for steeel and one for acrylic, although a spindle slow enough for the steel will probably still work for acrylic, just much slower.
    Dec 2006
    247
    I would use a cool mist to spray coolant on for steel you can find them on msc for around $100 but your rpm is going to have to be so much slower I don't even know if you can get a router that slow around 1000-2000 rpm if you have to, use a carbide bit and take small depths of cut like .050" and feed it faster with the mister you should be ok at best.
    Dec 2005
    29
    Yeah, Somehow I dont see being able to use the same tool for cutting acrylic and steel... Possibly if I did a true spindle type mount - with some radical gearing options between the motor and spindle.
    However at this point its probably easier to just build the Z axis to accomodate 2 different tool mounts.
  1. PIC Embedded design Question
    By musicmkr in forum PIC Programing / Design
    Last Post: 07-24-2010, 04:29 AM
  2. newbie question about router design?
    By cdsgraphic in forum DIY CNC Router Table Machines
    Last Post: 01-10-2007, 03:50 AM
  3. auger design question
    By erase42 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2006, 05:13 PM
  4. new table design question
    By KTP in forum DIY CNC Router Table Machines
    Last Post: 07-21-2006, 10:21 PM
  5. Gantry design question
    By anthony in forum Mechanical Calculations/Engineering Design
    Last Post: 04-27-2005, 07:39 PM
