586,067 active members*
5,047 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > prebuilt cnc wire foam cutter machine recommendations
    Jan 2018
    Hello I would like recommendations on purchasing a CNC Foam wire cutter machine. I'm looking for a prebuilt version. Hotwirefoamfactory.com has some machines that look good. particularly the Sign Maker model seems like it would fit my needs.
    Is there any other company I should be looking at as well.
    thanks,
    Sep 2009
    Re: prebuilt cnc wire foam cutter machine recommendations
    Unfortunate you aren't getting any help. I was looking for the same thing.
    Tom
  1. First CNC Hot Wire Foam Cutter
    By TiboJ in forum CNC Wire Foam Cutter Machines
    Last Post: 12-08-2013, 05:06 PM
  2. rigid wire foam cutter
    By drzach in forum CNC Wire Foam Cutter Machines
    Last Post: 07-03-2012, 01:12 AM
  3. CNC hot wire foam cutter and USB controller
    By Kroko in forum CNC Wire Foam Cutter Machines
    Last Post: 08-23-2010, 07:29 AM
  4. Best wire for foam cutter ?
    By fomaz in forum CNC Wire Foam Cutter Machines
    Last Post: 12-22-2006, 09:17 PM
  5. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-17-2006, 02:57 AM
