587,048 active members*
2,749 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Need help to wire AKZ250 with VFD GT-4R0G-2
Results 1 to 2 of 2
    Jan 2013
    Hello to all
    One year ago I started building a large CNC milling machine.
    I've installed steper motors (nema42), dirvers, connected to AKZ250 and everything works great. But
    on the final step, when I came to spindle setup everything became very complicated for me.
    I hoped to find solutions on youtube tutorials, where everything is wired and configured in 5 minutes, but VFD that I got from China has different inputs.
    here is what I have:
    - this is inverter (VFD) manual
    - this is AKZ250 manual I'm try to use diagram on page 59
    this is inverter model: GT-4R0G-2
    my firs steps was like in youtube wiring - PWM, 10v from VFD+1k resistor in VI2 input, but it didn't work.
    After this I asked for help manufacturer, I asked how could I control VFD with PWM signal and this is what thay sent to me
    I've made the same vfd setup:
    P001 - 1
    P003 - 60
    P004 - 60
    P007 - 2
    P202 - 1
    and made wiring like this:
    Attachment 383838
    Attachment 383840
    and this is how it looks like, when spindlde starts on 2000RPM.
    https://www.youtube.com/watch?v=ihx0hqOVDq8
    I am very beginner in this and my electrical knowledge is very poor in this business. I dont ever understand how PWM +10v works.
    I will appreciate any help.
    Jan 2007
    626
    Re: Need help to wire AKZ250 with VFD GT-4R0G-2
    Hi Ja_Ja,
    I have the same Motion Card but a different VFD. I have just finished playing with this.....
    You say you are using the diagram on page 59 but your wiring is not the same as that diagram.
    Attachment 389432
    Your 'Pull Up' Resistor ( 1k ohm ) must be wired at the VFD as shown in the diagram.
    This gives you an approximation of a 0 -10V signal. The AKZ250 can ONLY output a PWM signal.
    The result will 'in the ball park' and can be tweaked by adjusting the VFD input signal parameters.
    Make sure your VFD IS actually outputting 10.0V. If its high, no amount of parameter tweaking will fix it.
    My VFD outputs 13v ( supposed to be 12V ) so I used a 10v voltage regulator.
    You should be able to get within 10% error.
    You also don't need the REV signal wire. There is no need to spin in reverse.
    Steve
  1. Setup and wiring of Mach3 USB 4 axis Motion Controller AKZ250 from Leafboy77
    By MartinBarfoed in forum Stepper Motors / Drives
    Last Post: 04-02-2019, 11:50 PM
  2. Spindle tach Index port/pin in Mach3 with AKZ250?
    By davesieg in forum Mach Software (ArtSoft software)
    Last Post: 12-28-2015, 12:01 AM
  3. USB AKZ250
    By latulippe6 in forum French
    Last Post: 07-02-2015, 05:42 PM
  4. AKZ250 USB controller - no output
    Last Post: 12-12-2014, 07:10 PM
  5. Spindle PWM not working with AKZ250 motion control card
    By curator_ami in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2014, 11:35 AM
