586,036 active members*
3,695 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Method to internal/external thread ?
Results 1 to 7 of 7
    Jan 2007
    38
    Hello,
    What would be the best way to go about adding a large fastener type thread to my design.
    Should I creat it from scratch?
    I am using progeCAD, most commands are the same as AutoCad.
    Pete Gallo
    Mar 2004
    150
    Proper helical 3d threads in autocad are impossible without addon LISPs. They are also completely unessisary for manufacturing drawings. In 3d just make a hole to the minor diameter of the thread, and in the layout if you are not making a section just draw two hidden lines representing the minor and major diameters.
    Jan 2007
    38
    thread
    Hi Impact,
    The part I have designed will be cut on a cnc mill (which I don't have yet). Also the large diameter (70 mm) internal and external thread will be done with the mill.
    If the thread is not in the part design where would it be plotted. Maybe with the CAM?
    I am new to this.
    Thank You
    Pete Gallo
    Mar 2007
    5
    thread milling is easy enough to program on the shop floor and you don't realy need to use cam for it
    In Heidenhain (not familiar with many other controlls) all you do is move out to the major dia of the thread (in x) then an incremental polar rotation of 360 degrees and an incremental z move of the pitch (with a thread comb type of cutter), up is better as you mill away from the swarf.
    Jan 2007
    38
    threads
    Thanks for the info. I would rather do it the shop than pull my har out with CAD.
    Nov 2006
    34
    Hello Pete.
    If you use Mach3 there are Wizards for the Internal & External threading..
    cheers
    Frans
    Jan 2007
    38
    to thread or not to thread
    Hi Syil_Australia,
    I do not have the CNC equipment as of yet but could you give me the name of the Wizards for the Internal & External threading so I can file the names for when I will need them.
    Pete Gallo
  1. 1/4 NPT External thread program
    By JerryH in forum G-Code Programing
    Last Post: 08-28-2008, 01:37 PM
  2. Internal Thread Grinders
    By Zumba in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2007, 03:28 PM
  3. 2-1/2 External NPT on Okuma Lathe
    By jdr1961 in forum G-Code Programing
    Last Post: 02-15-2007, 04:12 AM
  4. Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help
    By pandiyan.innova in forum Community Club House
    Last Post: 11-16-2006, 12:47 PM
  5. What's the best method to turn a thread and a 3/32" bore concentric?
    By Darc in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2006, 12:34 PM
