586,270 active members*
4,196 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Replacement Sabre 750 (850SX) Operator Assembly Required
Results 1 to 5 of 5
    Oct 2008
    11
    Angry Replacement Sabre 750 (850SX) Operator Assembly Required
    Hi guys,
    We have an old Sabre 750 with acramatic 850SX control. We took the operator assembly off the machine as the control buttons were not working (Massive pressure required to make the buttons work!!), we cleaned behind the panels, re-assembled... No display! DS3 + DS4 red LEDs light up on the back of the display but no graphics on the screen.
    Machine power off button causes screen to flash (like when turning off an old TV - white frame reduces to centre of screen and blinks out). Have had an experience ex-Cincinnati engineer have a look at the operator assembly but no joy. He is suggesting the unit is dead.
    Can anyone else suggest troubleshooting steps?
    Does anyone have a working spare they can part with??
    May end up having to replacing the entire machine otherwise!
    thanks in advance,
    Pete
    Oct 2008
    11
    Re: Replacement Sabre 750 (850SX) Operator Assembly Required
    oh dear - *bump*
    Mar 2014
    735
    Just spit balling here but it sounds to me like your electronics package/board is probably corroded. Open it up and take a look at it. Look for green or white discoloration where your inputs connect to your control board. If the circuit traces aren't ruined it might start working properly again if you gave it a good cleaning. Also, a dying power supply could cause similar problems. Test its output when its under load if possible. It should be outputting its rated voltage. Good Luck.
    Oct 2006
    71
    Quote Originally Posted by Peat View Post
    Hi guys,
    thanks in advance,
    Pete
    I have a sabre 750 with 850sx since 2004. One trick with the keyboard is to warm it up before use. I use a heat gun with a sheet of rubber folded over the front of the control if its less than 65 F in the shop. Blow the air over the keyboard. Does wonders for the keyboard. Monitor is standard VGA. I replaced mine with a 70$ ebay 13" LCD. Much nicer than the crt. The operator panel board is very sensitive to static or transients. I have an IC on my operator panel board that decoded the keyboard strokes go bad. I soldered a new on on and its been ok since.
    Also, the entire op panel can often be had on ebay for under 1K.
    Dec 2006
    584
    You need to contact SIEMENS and buy an up graded complete operator station with a LCD screen and new buttons. The buttons have always been a problem with the 850 SX control.
    MIKE CNC Machine Services INC | Cincinnati Milacron MachinesCNC Machine Services
  1. Sabre 750 acramatic 850sx parameters needed
    By jolulank in forum Cincinnati CNC
    Last Post: 10-14-2022, 05:02 AM
  2. Sabre 750 Acramatic 850sx Start Up
    By sheldo13 in forum Cincinnati CNC
    Last Post: 12-08-2021, 10:40 PM
  3. Acramatic 850sx on a Cincinnati Sabre 750
    By akcender in forum Cincinnati CNC
    Last Post: 08-04-2015, 06:18 PM
  4. Replies: 2
    Last Post: 10-13-2014, 04:24 PM
  5. Arrow 750 versus Sabre 1000 850sx
    By joe7sch in forum Cincinnati CNC
    Last Post: 03-24-2011, 03:56 PM
