586,061 active members*
4,463 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Syntec 6mb tool paths not aligned in y axis
    Jan 2017
    17
    Helppp
    Have syntec 6mb
    What can cause misalignment in y axis?
    Pocket tool path off by 3mm in y comparing to v90 tool path..
    Test panel ran perfect befor big job ran..
    Sent from my SM-G920F using Tapatalk
    Sep 2012
    228
    Re: Syntec 6mb tool paths not aligned in y axis
    You could have slop in you machine... but probably not.. since the V shape looks ok...
    I would suspect more of a programming issue...
    I don't know if the CAM is greating the GCODE correctly...
    Let us know what else is happening.
    I'm assuming you are making Doors... what software is this from?
  1. 4 axis tool paths not reracting
    By jredbolurne in forum Mastercam
    Last Post: 01-09-2018, 08:18 PM
  2. Live tool socket mis aligned
    By fmlfred in forum Daewoo/Doosan
    Last Post: 10-23-2017, 02:03 PM
  3. Replies: 2
    Last Post: 01-06-2017, 03:06 AM
  4. Controlling Z axis clearance tool paths
    By loddie in forum MadCAM
    Last Post: 06-09-2016, 12:22 PM
  5. Replies: 2
    Last Post: 04-24-2008, 01:47 AM
