Hello,
i have a mazak VTC-30C CNC milling with a Mazatrol M-plus control, i need to restart my program in the middle, say at a certain tool to avoid restarting from the top.
i found the function restart where i enter the program number and the sequence line number... and the search finds the right line and goes on it.
The only problem is that it shows an error: that there is no Feed or the feed is at zero..... i restarted at an M01 before the change, i tried at the T command, it always asks me to give it feed.
i thought it stays on G01 as a modal code, so i executed a G00 line on MDI to make it forget but it didn't work always asking me for feed even if i restart on a line with an F code...
the only time restart worked is when i put it before the first tool change of the program which dosn't help much....
any ideas on the subject??
