586,117 active members*
3,606 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > Citizen Prep page, increasing diameter value
    Nov 2011
    16
    I have a straddle knuler that sits well below my turning tools on the change. I need to make the dia on the prep page larger then the 2.0 value the machine currently allows. Anyone knows how to change this parameter or work around this issue? I know the gang will come up higher, since it has to for tools 11-14 on the dogleg.
    Nov 2014
    26
    Re: Citizen Prep page, increasing diameter value
    Use man set and increase the dia value
    Apr 2017
    7
    Use a G50U- shift once your tool is called up in the program. This will allow you to exceed the 2.0 that your machine is limited to. Just don't do a Position Point with your stock hanging out of the GB or you will crash.
    Feb 2011
    353
    there is a value you can change to let you use more than 2.00 in the prep page
    i am not at work now but will try and find the procedure to let you do this ( i have done it on a a20 vi and a20 vii) if this will help you
  1. CNC Prep, CNC Math, etc. etc. etc.
    By waltraud in forum Tormach Slant Lathe
    Last Post: 04-12-2016, 01:24 AM
  2. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum DIY CNC Router Table Machines
    Last Post: 12-24-2007, 09:51 PM
  3. Shaft Diameter, LeadScrew Diameter, Motor Torque?
    By cnc-newb in forum Uncategorised MetalWorking Machines
    Last Post: 12-15-2007, 04:25 AM
  4. Arrow, Page Up & Page Down Keys - Rhino Video Tutorial
    By Robert Schutz in forum Rhino 3D
    Last Post: 04-25-2006, 04:09 PM
  5. NC reading tool length from offset page, not data page..?
    By RMagnusson in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-21-2006, 11:07 PM
