586,051 active members*
3,712 visitors online*
Thread: Db25-1205
    Jan 2018
    5
    Db25-1205
    Just a quick newbie question. If I want a 3 axis with 2 steppers on x. For a total of 4 steppers, can i hook all of them up to a db25-1205 breakout board?
    Mar 2007
    2083
    Re: Db25-1205
    provided your control software lets you slave one axis output with another
    the only restriction if your connecting the breakout board to a PC's parallel printer port
    will be assigning the 4 out pins from the same data latch ,
    preferably pins 2 to 9 - that would of sent the data to the printer
    say 2 & 3 for the master X axis and 4 & 5 for the slave X axis , 6 & 7 for the Y axis and 8 & 9 for the Z axis
    don't use 2 pins from the data latch (pins 2 to 9) and 2 pins from the control latch (pins 1 , 14 , 16 & 17)
    John
    Jan 2018
    5
    Re: Db25-1205
    Thanks John. I will be using Mach 3 for the software. I was just wondering about the hardware. So i wire them all up the same and slave one in mach3? Im sorry about all the questions but im still in the purchasing of parts stage and want to make sure im purchasing the correct things. Thanks
  1. Db25 1205 bob
    By brontoo26 in forum DeskCNC Controller Board
    Last Post: 09-08-2018, 08:03 AM
  2. LinuxCNC and DB25-1205 board
    By routalot in forum LinuxCNC (formerly EMC2)
    Last Post: 08-29-2018, 09:30 AM
  3. Possible problem with BOB db25-1205
    By Lc1975 in forum Stepper Motors / Drives
    Last Post: 06-12-2016, 08:22 PM
  4. db25-1205 controller question
    By wmpinion in forum CNC Machine Related Electronics
    Last Post: 04-24-2015, 02:25 AM
