Hi there a friend of mine has asked me to build him a Metal Cutting/milling 3 axis CNC machine. I know in principals it is similar to a wood cutting CNC machine, But i know I have the
Following Challenges: I should mention that this is a 1200*900*700 mm Machine
- What material to use for my Chassis, I would say It should be I beam of some sort?
- What would I select for my rail and wagon, Is it similar to Wood or some thing else?
- what would the better choice Step Motors or Servos? is step motor a possible choice generally speaking?
- Moving System, I believe should be Ball and Screw? Do I need to Install 2 Motors on the sides of me table for my Y Axis or One in the middle is recommended?
- and any recommendation on how to build the protective Structure is greatly appreciated.
also is milling Possible with lets say a laser cutting machine? Or laser CNC machine are basically a 2 axis Machines, and one just can not control it in Z direction?
otherwise is a process like are clearance possible with laser CNC Machine?
Regards
jhonansaro
