586,094 active members*
4,055 visitors online*
Results 1 to 6 of 6
    Jan 2018
    as soon as i load g-code in mach3 my scale is out
    I have a zenbot 48 x 48 with a g540 controller. As long as I don't have G-Code loaded into mach3 it runs to scale, but as soon as I load in G-Code that I have made from Aspire or artcam the scale is out almost a quarter inch. I have tried to get in touch with Sean at zenbot for a couple months now with no response. I have checked to make sure that all of my programs are set too inch units. I'm at a complete loss. If I load a wizard in mach3 it will actually cut to scale. I have attached the setup file that was sent with my CNC for mach3 and G-Code file from Aspire.
    Dec 2014
    103
    Re: as soon as i load g-code in mach3 my scale is out
    Is your Cut set to the outside of the line? If your using a 1/4 bit and cut on center your part will be 1/4 inch small.
    Are your native Units in Mach3 set to inch or metric?
    Is the g-code in inches or mm's?
    Jan 2018
    that was the first thing that crossed my mind when I realized it wasn't cutting too scale. I have redone the tool paths so many times it's not even funny. LOL
    Weather I have it cut on the line or offset it's still the same.
    Jan 2018
    my native units in mach3 are set too inch.
    15362
    Quote Originally Posted by jowood69 View Post
    Remove these codes one at a time, this may not fix the problem, they are codes that are not needed to run this program
    G70
    G91.1
    G94
    Mactec54
  1. G-Code Ripper - Scale, Rotate and Split G-code
    By scorch in forum OpenSource Software
    Last Post: 08-26-2020, 03:28 PM
  2. Mach3 Doesn't load all the G-Code
    By docileroo in forum Mach Software (ArtSoft software)
    Last Post: 04-17-2014, 02:23 AM
  3. Scale in mach3
    By Bob Hallinan in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-28-2013, 03:28 AM
  4. Cut3d g-code changing "scale" in mach3?
    By LaGrasta in forum Vectric
    Last Post: 10-08-2012, 01:10 AM
