586,071 active members*
3,840 visitors online*
    Jul 2012
    28
    CO 2 laser lense
    Dear friends ,
    Can you tell me wich is the diference between a lens with the focal lengh 63.5 and a lens with FL 127
    Why are different FL ?
    Does FL determin the best choice in cutting a specific material ??
    Please help me undestand this difference between lenses
    Regards ,
    Costin
    Oct 2015
    96
    Re: CO 2 laser lense
    Lens with FL 63.5mm on 60W CO2 Chinese laser: engraving most popular materials, moderate "hot spot" size, moderate energy density, moderate DOF (depth of focus). Cutting some materials as thin acrylic, wood etc 2-5mm.
    Lens with FL 127mm on 60W CO2 Chinese laser: probably not really usable due relative low energy density. Very wide DOF, but will have limited effect on most materials. Maybe can be used to engrave on extremely uneven surfaces - as for example bark/cork with strong texture. You can try to cut thicker (2-3cm?) some foam-type materials, but can't guarantee effect - as depend strongly from material itself and setup. I suppose will work well on 100-150W laser - for cutting effectively very thick materials as few centimeters foams. Maybe other thicker materials as well.
    Polish @ Éire
  1. 60W Chinese Laser Lense Help
    By smatt in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-14-2016, 09:32 PM
  2. laser beam split after cleaning tube lense
    By Eimantas in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-02-2013, 10:03 AM
  3. How to Change Focus Lense
    By wolfau in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-03-2013, 12:40 AM
  4. Flying Optics and Lense Diameter
    By HughRob in forum Laser Hardware
    Last Post: 01-12-2011, 02:52 AM
  5. spherical fresnel lense
    By coykiesaol in forum Mechanical Calculations/Engineering Design
    Last Post: 11-03-2010, 01:03 AM
