586,103 active members*
3,370 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > Gibbs New Interface/ Trash Can Missing
Results 1 to 15 of 15
    Aug 2005
    50
    I downloaded the eval version of Gibbs 2017 v12 to try out and the trash can is missing as is the progress bar. Not sure where they went. Anyone have any idea where I can turn these on or do I have a corrupt download from Gibbs? I really like my 2016 version 11 and wanted to try v12 out before I took the plunge. I can't do that until I can find the trash can and the progress bar. Thank You for any help.
    15362
    Re: Gibbs New Interface/ Trash Can Missing
    Quote Originally Posted by Sierevello View Post
    Why do you need the trash can, have not used it in 10 years, or more if you want to remove something, just select it and press Delete key on your keyboard
    Mactec54
    Aug 2005
    50
    The whole progress bar is missing too. Have no idea where it went.
    Aug 2005
    50
    This is missing: Click image for larger version.
    15362
    Did you down load the full package
    Mactec54
    Aug 2005
    50
    Yes... I even downloaded it 3x and uninstalled and re-installed and no luck.
    15362
    Contact Gibbs, they are good about, fixing or finding problems with down loads, if that is what is the problem, I had trouble down loading this new version, but got it in the end
    Mactec54
    Aug 2005
    50
    Thank You MacTec!!!
    Apr 2005
    88
    They are still there. They are in the bottom right hand corner.
    Attachment 384768
    There are a couple reasons for this. There were two different process graphics. There was the bar at the top for system process and the pop-up for process...process...you know what I mean. All processes are combined and condensed in that bottom flyout. You can pin it to be always open if you always want to see what is going on. As far as the trashcan, it is down there too. Way back in the day, having a trashcan icon in the lower right wasn't that big of a deal because the displays were so small. Dragging and dropping was quick and easy. But now with the bigger monitors, there is a lot of real estate to cover from the left tile list to the right. As MacTech54 pointed out, hitting delete is now the preferred method of clearing a tile. There is also a new and maybe better way to clear the process tile list. There is now a "Clear" button right above it. This will clear the contents of the process tile list.Attachment 384770
    No funtionality was taken away with the new version. Things have just been updated and modernized.
    Aug 2005
    50
    Quote Originally Posted by mdlmkr View Post
    Attachment 384768
    Thank you for the reply mdlmkr. Which bottom flyout are you talking about? I still cannot locate it. Any chance you can send me a screen shot of the flyout showing the progress bar and trash can location?
    Thank You!!!
    Aug 2005
    50
    Attachment 384768
    I have taken a screen shot of my Gibbs. As you can see I don't have anything in the bottom right hand corner. I just wanted to try to make it more clear what I am talking about. If they are there, they are hidden and I cannot seem to pull them up. I contacted Gibbs and they said to use the recovery tool. I did as they said and I still do not have the process bar. Any help greatly appreciated.
    Thanks!!!
Name:	Gibbs v_12 screen shot.jpg
    Aug 2005
    50
    Okay I went to the Gibbscam Quick Start Guide just to make sure I wasn't crazy and it shows the process bar where it should be. It also shows the pin that mdlmkr was talking about. I just need to find out how to get the thing turned back on so I can pin it in place,
    I have tried right clicking down there and everything else I can think of and no luck and I can't find anything in the menus to turn it on/off.
    Thanks.
    Aug 2005
    50
    Thanks.
    Gibbs sent me another thing to try and it worked. It has returned to the bottom right part of the screen. It is below in case you ever experience it.
    Please try deleting the User Preferences folder by following the instructions below:
    Go to the Plugins menu at the top
    Select Pathfinder
    Select User Preferences
    Close GibbsCAM
    Delete everything within the User Preferences folder
    Upon relaunching, GibbsCAM will rebuild everything that it needs.
    Thanks for all of the help.
    Apr 2005
    88
    It looks like you are missing the commands across the top too. Is that correct? If so, it may be a windows setting...I will check.Click image for larger version.
    You need the trash can to toss Gibbs into it and move on to Autodesk to not have to deal with all the intermittent issues and the fact they give you a 15 yr old post processor that conflicts with their own program. My goodness 3D systems is terrible and I’ve never experienced more frustration. Add to that their customer service is short of poor. 2 months no cal back, nothing. Told them several times leaving messages the post processor is problematic with user issues and the machine doesn’t recognize its protocol. So yes a garbage can is a good thing.
  1. Trash in the rs-232 line
    By Michael82 in forum Fadal
    Last Post: 03-12-2009, 06:53 PM
  2. This forum is no trash bin.
    By svenakela in forum Mechanical Calculations/Engineering Design
    Last Post: 01-12-2009, 08:05 PM
  3. Got trash. need info
    By methuso in forum Stepper Motors / Drives
    Last Post: 04-20-2006, 02:21 PM
  4. Trash or Treasure:})
    By Bubba in forum Uncategorised MetalWorking Machines
    Last Post: 10-16-2004, 12:27 AM
