586,036 active members*
3,831 visitors online*
IndustryArena Forum > Community Club House > General Off Topic Discussions > Best CNC Lathe simulation software - Verify code prior to running
    Dec 2011
    34
    I teach CNC at the high school level. All of my students learn Manual G code by programming off line and running on a machine once the code has proven to work. I have a Prolight mill and the CNC base that comes with the machine is the software I use for this application. It has served me well and the students enjoy being able to verify each line such that they can see they are on track.
    I also have an older Emco CNC lathe running the welturn software. This software also has a fairly good simulator built into it.
    I am now running two Concept turn 60 Emco CNC lathes. I have been looking but have not had much luck finding a reliable and inexpensive simulation software for this application. Does anyone have a software they would recommend?
    Many thanks
    Dec 2015
    7
    Re: Best CNC Lathe simulation software - Verify code prior to running
    I prefer CNC simulator pro personally which is free for the 1st month. Also, there is a good list of open source software at https://www.shapeoko.com/wiki/index....viewing_G-Code
  1. Replies: 0
    Last Post: 07-02-2017, 02:39 AM
  2. Running a verify on a Milling Stock looks distorted.
    By jmorgan214 in forum BobCad-Cam
    Last Post: 05-18-2016, 02:52 PM
  3. Free CAD/CAM Mill/Lathe Software with Simulation
    By LeakyRivit in forum Uncategorised CAM Discussion
    Last Post: 08-17-2015, 04:28 AM
  4. Artisan software running my Hardinge HCNC lathe
    By JimFerguson in forum Hardinge Lathes
    Last Post: 08-14-2014, 07:52 PM
