586,067 active members*
4,899 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Mach Wizards, Macros, & Addons > How to have Mach3 use an Auto tool zero location on the table for Zero of tools.
Results 1 to 14 of 14
    Mar 2017
    173
    Hi
    At the moment I have a touch plate with a set thickness which I place on my stock and touch it to set the Z zero for my operation. When I change a tool I place the plate again on the material to zero again the next too.
    Yet this creates some problems like when material has been removed and now my material top is lower than the original Z height, so I either need to compensate the difference after I zero on the lower height or have a different setup in the cam for the next tool, or some times there is no flat area left to position the plate so I can touch it and I have to position the plate on the table and touch both tools and do calculations to find the correct height etc.
    Is there a way to set a touchplate on a fixed location on the table and after I zero my first tool on the part have mach3 touch each next tool on that fixed location and apply the correct Z height on each tool on its own?
    Re: How to have Mach3 use an Auto tool zero location on the table for Zero of tools.
    Mach Standard Mill will do what you want. I've been using it for about 5 years.
    Mar 2017
    173
    Hmm
    Didn't know about this screen set and it seems very interesting. I will spend some time looking into it. I don't feel very comfortable thought replacing my whole screen set but I will consider it. Is there any other way that I can do it on the original mach3 screen set?
    Feb 2007
    4553
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Feb 2007
    4553
    Mar 2017
    173
    Quote Originally Posted by jalessi View Post
    Yep
    That is exactly what I am looking for. How can I do this on my mach3? What macro do I need?
    Feb 2007
    4553
    Gerry sells his 2010 screenset for only $20.00
    Feb 2007
    4553
    Mar 2017
    173
    So I need to change my screenset as it seems, right? I cannot do it on the original screenset?
    Feb 2007
    4553
    Jim,
    You may want to contact Gerry "GER21" and ask him if he would sell you just the macro for the tool setter instead of his entire screenset or try contacting the authors of the other videos, there is a possibility that they may share their macro code so that you can use the original Mach3 screenset.
    Jeff...
    Feb 2007
    4553
    Jim,
    Take a look at the (6th) sixth post of the attached link:
    https://www.machsupport.com/forum/in...?topic=32948.0
    I can't guarantee it works correctly however it may give you some insight.
    Mar 2017
    173
    Jim,
    Interesting.
    I will take a look into it too. Thanks!!
    Edit: I studied it and from what I understand it doesn't apply offset on the tool but sets the g54 Z zero to the probed height. Correct? It is a little more automated version of what I do at the moment.
    Quote Originally Posted by jimskeet View Post
    You can do anything you want with the original screenset, if you know what you are doing. This thread should have all the info you need.
    http://www.cnczone.com/forums/mach-w...x-version.html
    Mar 2017
    173
    Thanks Ger21 I will read the thread you mentioned. I hope I will figure out how to do it with the info on it.
  1. Auto tool zero doesn't stop in Auto Tool Zero routine on Mach3
    By Flintstone in forum WoodWorking Topics
    Last Post: 09-05-2017, 07:00 PM
  2. Auto Tool Changer reed switch Home location
    By ballistic42 in forum Benchtop Machines
    Last Post: 12-15-2016, 06:09 AM
  3. MACH3 AUTO TOOL ZERO MACRO
    By ZZRBlokey in forum Mach Wizards, Macros, & Addons
    Last Post: 04-12-2015, 06:57 PM
  4. Mach3 ATC & Auto Tool Zero
    By KNA in forum Mach Software (ArtSoft software)
    Last Post: 02-03-2015, 10:16 PM
  5. Ayuda con Auto Tool Zero en Mach3
    By hmoltedo in forum Spanish
    Last Post: 12-06-2011, 02:58 AM
