586,108 active members*
3,027 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Countering Part Lift On Sliding Jaw Chuck
    Apr 2007
    Question Countering Part Lift On Sliding Jaw Chuck
    Anybody Got Any Ideas To Combat Part Lift On A Sliding Jaw Chuck?
    4826
    Remachine the chuck jaws?
    Use a tailcenter.
    Reduce overhang.
    Reduce depth of cut.
    Reduce feed.
    Machine a stop plate to go against the spindle nose, but fit snugly inside the chuck. This will allow you to dead end a certain range of parts against a stop and prevent push-through. You can be imaginative and add a threaded stop bolt in such a plate, to increase the useful range.
    Apr 2007
    Cool
    Thanks for the input, but what I am trying to overcome is the lifting action of the jaws due to the sliding master clearance(combined with the jaw/bolt distortion from chucking). Wondered if anybody had come up with a jaw design that incorporated a pullback feature.
    Dec 2006
    18
    Are we talking soft jaws on a 3 jaw lathe chuck? If so I've found that boring the jaws on a taper so they get bigger in dia. closer to the chuck will help get better part contact at high chuck pressure, especially with longer jaws, .001 per inch is a pretty good starting point, then when you clamp the part start clamping it lightly so that the jaws only contact at the outer tips, then increase the pressure untill the rear of the jaws make contact, if you get full contact at too low a pressure then rebore with more taper per inch. And always use a chucking ring at the rear of the jaws if you want accuracy.
    Apr 2007
    That actually was my next move but haven't done it yet. One thing that has helped to a degree is to insert a fairly hard piece of rubber or urethane inside the jaws below the part. The jaws grip the rubber first taking up all the clearance prior to gripping the part.
  1. Router lift project
    By Corruptor in forum Linear and Rotary Motion
    Last Post: 08-11-2010, 03:40 AM
  2. HF or Lift Arc Start for TIG
    By kramerda in forum Welding Brazing Soldering Sealing
    Last Post: 03-03-2007, 08:15 PM
  3. Lathemaster power lift
    By outlaw paintbal in forum Benchtop Machines
    Last Post: 06-24-2006, 09:44 PM
  4. Chuck Drill Chuck Alignment
    By TomV in forum Mini Lathe
    Last Post: 04-27-2006, 07:20 AM
  5. Concern with gantry lift
    By CuttersCov in forum DIY CNC Router Table Machines
    Last Post: 02-18-2006, 02:30 PM
