586,560 active members*
3,961 visitors online*
    Jan 2018
    Y-axis slaving
    I recently re-engineered my entire machine adding another rack the to the opposite side of the table and mounted a 4th axis to slave with Y. Using mach 3 I was able to slave the 2 axis together but now when the machine jogs on the Y axis Y2 Servo makes a decently loud buzzing noise while trying to hold position with Y1 (this action causes the table to shake until it reaches square.) This problem is causing circles and most other shapes I would cut to have a wavy rough cut and the only way I have been able to avoid that is to slow the machine wayyyyyy down and do multiple passes and still getting some interference and makes even my fast travel have to be very slow to get a semi accurate shape.
    Re: Y-axis slaving
    Sounds like either a servo tuning issue, or the gantry is so far out of square that the servo is struggling to keep it square?
    Jan 2018
    Re: Y-axis slaving
    gantry is pretty square. I'll try and tune the servo some more and see if I get any better results.
  1. USB Controllesr and Axis slaving
    By Joe2014 in forum Controller Cards
    Last Post: 10-11-2015, 07:28 PM
  2. slaving axis'
    By mklb in forum Mach Software (ArtSoft software)
    Last Post: 06-20-2012, 02:29 PM
  3. Slaving more than 1 axis
    By jlmold in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2011, 01:52 AM
  4. y axis slaving off
    By electric2u in forum Mach Mill
    Last Post: 04-29-2010, 02:17 AM
  5. slaving y axis motor for 4x8 cnc
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-25-2009, 05:27 PM
