586,069 active members*
3,431 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > solidcam geometry is invalid for milling an elipse
    Jul 2014
    221
    I've made an elipse in a sketch on a model which has a hole 75mm in diameter.
    the elipse is 75.3 by 75mm and when I select this sketch as a contour for milling an error ocurrs saying that the geometry is invalid.
    it worked on some earlier models with smaller holes and smaller differences.
    Mar 2017
    24
    Re: solidcam geometry is invalid for milling an elipse
    Hello Allenp
    How are you selecting the geometry for milling, ie: are you trying to mill in between the sketches? If so does the full diameter of the tool fit in between them? If the 75mm hole is a pilot hole then set it as "open" so that SolidCAM understands that there is no material there that it may collide with. Often times when you get the "invalid geomtery" error it is because SolidCAM misunderstands what you are trying to machine.
    You can always give us a call at the main tech support line or the tech support line of your local reseller ( if not in North America) and we can help you out with this.
    Mar 2016
    325
    if the message occurs at selecting stage the problem is that the sketch cannot be projected to machining plane.
  1. solidcam "geometry is invalid" on milling operation for on model engraving
    By allenp in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-29-2016, 11:21 PM
  2. solidcam naming drilling geometry to drilling radius automatically
    Last Post: 09-07-2015, 07:04 AM
  3. Solidcam Geomtry is invalid errors
    By ctzodiacartist in forum Mastercam
    Last Post: 12-23-2013, 05:07 PM
  4. Chain Geometry is Invalid
    By Rees Guitars in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-05-2009, 08:37 AM
  5. milling an elipse
    By gallzer in forum MetalWork Discussion
    Last Post: 02-23-2008, 02:10 AM
