586,116 active members*
3,460 visitors online*
Thread: G0602
    Jan 2017
    7
    G0602
    I have a G0602, I am thinking about converting to CNC. Just starting the research phase, and my first question is about motor and vfd upgrade. What are good options, that wont break the bank? Only requirement I have is keeping it 110v.
    Ed
    Aug 2016
    132
    Re: G0602
    Do you have access to a 20 amp circuit, or just a regular 15 amp circuit?
    If you only have a 15 amp circuit you are mostly limited to a 1 HP motor.
    Huang Yang VFD's are a common choice. If you want to avoid China, I think TECO and AutomationDirect have a few 110v options.
    Jan 2017
    7
    Re: G0602
    15 amp circuit, I think A 1hp motor should be fine for the work I am doing. Thanks for the input, will check them out.
    Dec 2006
    108
    Re: G0602
    A number of folks have already done this so search the forum for their solutions.
    Some ideas from my build can be found in this post towards the bottom: http://www.cnczone.com/forums/vertic...m-posts-4.html around thread #46.
    Best Regards.
    Carl
  1. G0602 conversion
    By Transformer1626 in forum Vertical Mill, Lathe Project Log
    Last Post: 08-07-2014, 04:13 AM
  2. G0602 Spanner Nut
    By photomankc in forum Benchtop Machines
    Last Post: 04-27-2011, 06:36 AM
  3. G0602 Measurement
    By michaelthomas in forum Benchtop Machines
    Last Post: 04-26-2011, 03:47 AM
  4. G0602 3 jaw chuck
    By tmbg in forum Benchtop Machines
    Last Post: 11-15-2010, 08:15 PM
  5. G0602
    By eartaker in forum Benchtop Machines
    Last Post: 08-20-2010, 09:35 PM
