586,036 active members*
3,488 visitors online*
IndustryArena Forum > MetalWorking Machines > Knee Vertical Mills > 1980 wells index 805 cnc "rebuild" and update
Results 1 to 5 of 5
    Jan 2018
    9
    I picked this mill up a little over a month ago. It's been disassembled and put back together. I brush painted it with some custom por15 after stripping most of the original paint. I say "rebuilt" because it didn't really need parts, just naval jelly and special grease.
    As far as electronics are concerned, I went with the acorn board. I like the Idea of a processor on board, industrial software, probing, and probably some stuff I don't understand yet. Not to mention us made.
    For motors I went with med inertia in 750w dmm tech, and dyn4 drives. 3 for now and a rotary axis later.
    I got a great deal on an elo 16" touchscreen and medical office articulating arm to hold it.
    Right now I am building the cabinet and wiring.
    Most of my background relating to robots is in 3d printing, so I have quite a bit to learn.
    Some of my questions ...
    The drives get 30a each for a total of 90 without the 3hp motor? Holy **** is this Right?
    My 3 phase power has a wild leg,hot let, stinger leg, hi leg or whatever you want to call it, should I address this?
    Jan 2018
    9
    Re: 1980 wells index 805 cnc "rebuild" and update
    Anyone on the hi leg?
    Jan 2018
    9
    My arm came in yesterday. It's pretty nice, maybe too nice. I had to add a brace so it didn't fly away when I touch the screen. All my cables will be arriving soon.
    Jan 2018
    9
    Thanks for all the help everyone
    Dec 2013
    5717
    Quote Originally Posted by Clayforrey View Post
    30 amps is the max momentary output of the drives. In operation they won't draw anywhere near that much power. 30 amps of 230V, 3 phase should be more than enough for the entire machine.
    The only time this would become an issue is if you are splitting off 120V power using the neutral, then you would need to make sure that you are not using the wild leg. Between the phases, you will have 230V.
    Nice looking machine. :cheers:
    Jim Dawson
    Sandy, Oregon, USA
  1. Replies: 3
    Last Post: 06-16-2014, 09:36 PM
  2. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  3. Replies: 2
    Last Post: 02-17-2013, 02:49 PM
  4. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  5. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
