I designed couple of mods for my machine last week and sent out the circuit boards to be fabricated. Courier just dropped them off.
Power Drawbar mod: Two reasons for this one; first, I did not like how it operates by keeping the button pressed. I know there is a foot pedal and I am not sure if you can press for release then relax or go away then press again to engage. If it wasn’t for the 2nd reason, I would have probably investigated the foot pedal.
The mod allows pressing once to release, then pressing again to engage. With a neat feature that it goes back automatically up if nothing happened for 10 seconds (or 20, 30 sec options). This is just so if I got distracted with a phone call or took too long to put the other tool, then the controller pulls back the bar so not to keep tension on the bar. I can change the time for auto-return by using the top button on the pendant to cycle between the auto-return time options.
The 2nd reason is Safety; when I was installing the PDB, I really thought the two blue wires (105/106) that goes from the PDB to the main control board is for the machine to tell the PDB circuit that the spindle is running, so the PDB does not operate. I was mistaken, I discovered that the two blue wires are really for the PDB to tell the machine that it is going down! So if the spindle is running, then the machine stops it ( similar to opening the door)
As an engineer that been designing control systems for the past 20 years, this did not make sense! So the drawbar will be pushed down even if its rotating 1000’s of RPM! Well, I had to try it (Doh!!) I put the spindle at the lowest RPM, no tool inserted. Pushed the button, guess what?! Spindle started to stop (it winds down) drawbar got pushed down, locking the R8 adapter and while the bar still winding down, it unscrewed the R8 adapter, it got dropped on top of my surface and I got a small ‘visible’ dent to remind me of that.
I realize that probably no one would want to push the button while the machine is cutting but its not really hard for this to be done correctly in the first place. If the spindle is running, PDB should not be allowed to operate. In design world; we can’t assume the operator is professional enough to understand and not do certain things; design should be for the village idiot (no pun intended) and goes up from there. Only in the issues that can’t be resolved in design, then we rely on education/training and increase awareness.
This is a microcontroller board with straight forward installation, the RJ11 from the pendant goes into the right port, a small straight RJ11 goes to the left port and that's all, the microcontroller now took over the pendant and tells the PDB when to release or pull up.
I optimized the firmware so the whole board only consumes 0.5 milliamps. And added full optical isolation circuit to accept external control from another board which tells it if the spindle is running or not. The isolation keeps the entire PDB isolated from the machine power supply as PDB has its own power. Of course, the standard PDB operation is still the same, if power got lost, then it returns (if it was released) also if air-pressure lost. The same limitations as before.
Digital Load Meter: The 2nd Mod which now required to tell PDB not to operate. I checked if the Tormach control board provide output when the spindle is running, but no such output found, so the only way to know the spindle is running is to use the provided signal from the VFD standard load meter output.
The VFD provides a perfect load indication output for external use. I could have just connected it directly to the above PDB microcontroller; but I figured as long as I am connecting to the load output, might as well display it. I am just waiting for the 2.2” TFT LCD display to arrive so I can finish the firmware and board for the load meter. This board uses the PDB optical isolated connection when there is a load on the spindle. Hopefully the LCD will be arriving in couple of days and will make a video about it once installed.
Now that this is tested on the machine, I need to make the machine cut the plastic cover to fit the two RJ11's as they stick out of the cover. No difference than my 3D printer which makes part for itself, the 770 is also cutting parts for itself. When I have more time on Fusion 360 I may make a full aluminum enclosure with a magnetic base so it sticks to the back of the column, but then I should keep it outside to be seen, no point of cutting something shiny then hide it
And by the way guys, the single hand operation in the video was not a showoff, its just I was taking a video, I do really use both hands to change
Here is the video…let me know what you guys think, ideas for improvement, flames, all the norm
<span style="font-family: Arial">https://youtu.be/XTAzURYqd9M
