586,102 active members*
2,433 visitors online*
    Apr 2016
    43
    DM4400 Pull Studs
    Hello
    What type pull stud does the 4400 use ?
    BT30 45,°60°,90° or iso30 type ?
    I did look in the dm4400 manual but it only says pullstuds are supplied by Dyna.
    Nov 2012
    367
    Re: DM4400 Pull Studs
    It uses a custom knob. I need to confirm a dimension, but I believe the attached drawing is correct (but note the DM4400 in the lower right, so it almost certainly is). However, that is probably only for reference. I have mixed feelings about whether or not you would want to make your own. RTS does sell the knobs, but they are not cheap. Their part, 341-14, is $26.46/ea and are apparently stocked. The price is kind of brutal, but thankfully you don't need a ton of them. If you find them less expensive elsewhere, please post here!
    Dyna DM4400 retention knob.pdf
    https://www.retentionknobsupply.com/
  1. DM4400 pull studs
    By 2ferrous in forum Dyna Mechtronics
    Last Post: 06-21-2021, 05:32 PM
  2. Pull studs
    By Scrambled1 in forum HURCO
    Last Post: 11-20-2016, 08:19 PM
  3. need DM2900/DM1007/DM4400 pull studs!
    By acannell in forum Dyna Mechtronics
    Last Post: 12-13-2013, 03:50 PM
  4. Which CAT 40 pull studs?
    By sortafast in forum Uncategorised MetalWorking Machines
    Last Post: 08-03-2013, 05:28 PM
  5. pull studs
    By najnielkp in forum Uncategorised MetalWorking Machines
    Last Post: 06-12-2009, 02:42 AM
