586,051 active members*
3,748 visitors online*
    Dec 2017
    18
    Just need some more help
    First I want to thank all who have responded to my questions, It has helped a lot.
    Now for my question. How can I control the z axis. When I press start the first thing that happens is the spindle moves up off Z zero so it can move to the first cut. If my project is less than 3/4 thick than I have no problem. But if I have a project that is 1 1/4 thick than the spindle comes up to far and hits the stops. How do I control how far the spindle comes up off of zero when I first press start.
    Thank You,
    Dennis Killian
    AKA capdenny
    Apr 2004
    5737
    Re: Just need some more help
    If this happens when you run a G-code program, it's probably something that's set somewhere in your CAM software. But since you don't indicate which software you're using, it's hard to say how you'd change it. It might be in the post-processor, or it could be somewhere else. Look for something that indicates a "safe height" or "tool change" position.
    Andrew Werby
    Website
    Dec 2017
    18
    I am using mach3 software for machine. control and vcarve to make the gcode
    Mar 2007
    In vcarve go to toolpaths click on machine setup, go down to where it says rapid Z gaps above material, change the clearance number so it clears your material.Click image for larger version.
