586,089 active members*
3,924 visitors online*
    Jan 2010
    36
    Would Like to switch to RD Works
    I have a RedSail X700 that came with AutoLaser software and the machine control software is Laser Engraving Control System-TL-403. I'm not connected directly to the machine so I output a .out file from Laser Works to a thumb drive that I bring to the machine.
    I'd like to use RD Works v8 instead of AutoLaser. Does anyone know if I can do this? Will it output a .out file that will work in my machine? Anything I need to know about switching?
    Any help would be appreciated.
    Tom
    Re: Would Like to switch to RD Works
    Hi, Tom
    All you need to do is changing the control panel to Ruida, and remember how those wires are connected with each other, you should be fine.
    Achilles
    Tripro Technology
    www.tripro-tech.com
    Jan 2010
    36
    Thanks for the response.
    That solution is a lot more involved than I'd hoped and for now it's not a possibility. I guess there is no simple solution so I'll have to live with AutoLaser.
  1. Replies: 1
    Last Post: 06-29-2017, 07:37 PM
  2. Replies: 0
    Last Post: 05-01-2013, 05:00 PM
  3. Only Y works correct X don't work Z works one direction only
    By jdgbadenhorst in forum Hobbycnc (Products)
    Last Post: 06-10-2012, 09:54 PM
  4. Newbie Home switch and Limit, how it works ?
    By Calico in forum Uncategorised MetalWorking Machines
    Last Post: 10-05-2005, 09:53 PM
  5. Newbie Home switch and Limit, how it works ?
    By Calico in forum MetalWork Discussion
    Last Post: 08-03-2005, 05:22 AM
