586,051 active members*
3,945 visitors online*
    Oct 2003
    128
    Mach 3 Motors won't sit still
    I have been running my Mach3/Intergra (closed loop option) machine for a few years no problem with Maxsine drives & servos. A drive recently failed and I changed drives to the next larger model (TL10F to TL15F) which required setting parameters and re-tuning the drives. So I got that all done and everything mostly works.
    However when Mach is running the DRO's for X & Y are bouncing around by .0001 or so. There is a monitor utility in the Maxsine software that confirms the motors are actually moving. If I kill Mach the movement stops. I'm trying to figure out what I missed.
    Thanks for any input!
    Marc
    Jun 2010
    4256
    Re: Mach 3 Motors won't sit still
    Ah, but what is the size of a single step on your machine? If it is less than 0.0001 then you may have a problem, but if it is bigger, then the floating point arithmetic may be fooling you.
    In any event, it not at all uncommon for a servo drive to dither over the least significant step size. Few controllers have a dead-band setting.
    Cheers
    Roger
  1. Replies: 4
    Last Post: 03-29-2017, 01:59 AM
  2. How do i set up 2 X axis motors with mach 3?
    By Ncrazyballa in forum DIY CNC Router Table Machines
    Last Post: 11-26-2013, 03:15 AM
  3. how do i slave motors together without mach 3
    By austinblake92 in forum CNC Wood Router Project Log
    Last Post: 10-20-2013, 11:19 PM
  4. Synchronizing two motors in Mach 3
    By jeremyrockjock in forum Mach Software (ArtSoft software)
    Last Post: 10-24-2012, 11:34 PM
  5. Is it mach 3, power supply or motors?
    By tauscnc in forum Mach Mill
    Last Post: 12-06-2008, 03:17 PM
