Does anyone know what can cause the machine to not move in rapid or feed mode when the spindle is not turning? We checked parameter 3708 SAR bit and it is off, we checked stroke limits and safety zones and they are not used. The machine homes properly after power up (uses dogs). Tool changer works properly. We checked all Parameters and Keep Relays and compared them to the original printouts kept in the control behind the machine and all are good. Nothing out of the ordinary. It's also in Feed Per Minute, not Feed Per Rev so that isn't a factor either and wouldn't cause non-rapid moves with the spindle off anyway.
Time to pull my hair out.
Fanuc iO control.
3 axis VMC
