586,080 active members*
3,472 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Broken bit from bad connection of alligator clip!..ugh
Results 1 to 13 of 13
    Oct 2007
    446
    Question Broken bit from bad connection of alligator clip!..ugh
    So first time this has happened to me. I'm using 2010 screenset and was doing a tool change...put the bit in, connected my alligator clip to the bit and cycle start to probe to my fixed plate...only it didn't stop and broke the bit.
    Guess i'll have to always check the connection is working before hitting start....
    or does anyone has a different solution that using an alligator clip for better contact??
    Oct 2016
    128
    Re: Broken bit from bad connection of alligator clip!..ugh
    I never used the clips. My whole machine is grounded so I just used 1 wire to the touch plate and the other side of my ground was the tooling
    Oct 2007
    446
    well i could try running it to the router itself and see if that works? its a bosch colt.
    Oct 2016
    128
    Quote Originally Posted by airbrush View Post
    Idk about those spindles. I have a Colombo atc type.
    Bosch Colts have plastic bodies, and I think the spindle is isolated.
    You could always switch to a toolsetter, rather than a conductive plate. I plan on going that route in the future.
    Oct 2007
    446
    The lower section of the the bosch is aluminum...but not sure if its conductive to the tool though will try it...
    Just so convenient for tool changes with the 2010 screenset this way...
    Oct 2007
    446
    how is a tool setter different from a touch plate...i have no knowledge of these...are they just spring loaded?
    Spring loaded with a switch or sensor inside.
    Oct 2007
    446
    i see...so generally more reliable...
    May 2005
    3920
    Years ago we did one with a small plunger and a Baumer precision switch. If you have a lathe, a decent one is pretty easy to make. As for more reliable that is up for debate but we could get repeatability in the single digit micron range.
    Oct 2007
    446
    reliable ...as in it always makes contact and you don't break your bits...
    Oct 2007
    446
    anyone have a recommendation on which/where to get one?
    and how do this hook up as compared to a conductive plate?
    i'm using mach3, gecko 540 driver
    Nov 2008
    110
    I guess they actually break electrical contact when touched.
  1. Arcing connection on Laser CO2 tube connection
    By pcaulfie in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 11-06-2015, 07:00 PM
  2. Help with Clip art to Cam Bam
    By gmfoster in forum CamBam
    Last Post: 09-18-2012, 06:55 PM
  3. RFQ - Clip On Nut Cover
    By andygp in forum RFQ (Request for Quote)
    Last Post: 06-27-2011, 11:35 AM
  4. 3D Clip Art
    By ronateah in forum ArtCam Pro
    Last Post: 04-26-2010, 10:09 AM
  5. Looking for an e-clip alternative.
    By trilect in forum Smithy
    Last Post: 08-22-2006, 03:18 AM
