587,013 active members*
3,699 visitors online*
    Feb 2018
    new to cnc need help
    I bought a used DIY router table and finally got it working but when i move the y axis it is twisting when i run fast.
    i have 2 motors one is y the other side is set up as a. what can i do to make the bridge not twist.
    Re: new to cnc need help
    Go slower.
    It sounds like one axis is losing position. That usually happens when you go faster than the motors are capable of.
    Feb 2018
    Go slower.
    How do I slow the speed down when just moving axis by keyboard
    Apr 2004
    5742
    Do you have two motors and screws on the Y axis? (If this is the longest axis of the machine, which is typically used to move the gantry, it should be called X). If so, they should be on two separate drivers slaved together. If one is set up as an A axis, then it's not surprising they're out of sync - the surprising thing is that this works at all, since only one motor is working and dragging the other.
    If I'm misunderstanding and the axis moving the gantry is driven by a single motor with a screw in the middle, then this is a well-known phenomenon, known as the "stuck drawer" effect. You could rebuild the machine to have dual screws and drivers, or, as Ger suggests, slow it down so it doesn't happen. You can do that by limiting the maximum velocity in your CNC control program.
    Andrew Werby
    Website
    Apr 2009
    5516
    Quote Originally Posted by T7Specialties View Post
    If you have Mach3 then hit the tilde key (~) on the keyboard, will bring up the MPG screen then you can adjust the jog as a percentage of max velocity.
