hello . my machine iTNC530 HEIDENHAIN
when i just press on power bottom all axis give me to much vibration and the display got this message
8650 IZT value of power module is too high
can any one help me please
Unfortunatelly it's major failure of control hadware.
We had it in our iTNC and usually service would replace NC box, but our electronic guys replaced some microchips and it helped. Dunno what was it specificly.
thank you for reply
can you tell me what do u mean by (NC BOX)
8650 I2T value of power module is too high <axis>
Oscillation occurs. Mechanical problem. Too loose ball screew or bearing.
thanks all. what i did
1 i replace the all drivers from other machine x and y and z and power supply
2 i check all bearing . it is OK .also i check all rollers x and y and z . it is OK
3 i disconnect the x axis and try to run
4 i disconnect the y axis and try to run
5 i disconnect the z axis and try to run
same problem . and all drivers is running good on other machine
any one can help
Which axis indicates the error? (8650 I2T value of power module is too high <axis>)
Reduce the MP1510.x parameter to half! (.x=0:axis X, .x=1:axis Y, .x=2:axis Z)
please help ??
any one can help please
machine is stile down
no help up to now
please reply ?
no one have this error before
please help
HI, IN MY MACHINE SUDDENLY COMING DEVICE OVERLOADED NOT A SUCH PROPER ALARM AND THAN I CHECKED HELP ITS 24960 ALARM SHOWING CHECK FAN BUT ALL FANS WORKING FINE..
CAN ANY ONE TELL ME WHATS A ISSUE?
