586,069 active members*
3,425 visitors online*
Results 1 to 6 of 6
    Aug 2016
    32
    Editing .gpp files - How?
    I am using Linux CNC and have found some files in another post that allows me to post process the output of Solidcam to operate my machine.
    However, i need to edit one or two things in the .gpp file to make it work as i would like.
    I want to use mist cooling instead of flood and would like to change F8 to F7 and also delete G30.
    Previously i have changed them in the g-code but would like to do it in the .gpp file.
    I have opened the file in "Free file viewer" but can't edit it! I've "selected all in "Free file viewer" and opened it in Notepad, edited it but can't then save it as a .gpp file
    How do i edit the file and re-save as a .gpp file?
    No doubt a simple problem but a solution evades me.
    Mar 2016
    325
    Re: Editing .gpp files - How?
    It's standard text file so u can edit it by notepad or any text editor u like.
    It is simple basic script writen mostly using "if" loops.
    May 2013
    37
    Quote Originally Posted by bobhare View Post
    I have opened the file in "Free file viewer" but can't edit it! I've "selected all in "Free file viewer" and opened it in Notepad, edited it but can't then save it as a .gpp file...
    1. "Free file viewer" not editor
    2. If you open file in Notepad and make some changes just click ctrl + s then you file save original extension but if you choose save as.. From menu file then notepad making a new file with default extension like *.txt of course u can change this extension from txt on *.* and check name format should be looking like name.gpp
    Anyway that's is so funny
    Aug 2016
    32
    Thanks to you both. My brain must have gone to sleep.
    May 2013
    37
    No problem everyone sometime have same
    Mar 2021
    17
    Hi! Try VSCode + vscode-gppl-support extension.
    https://marketplace.visualstudio.com...false#overview
  1. RFQ: Convert SolidWorks files to MDD files for Hanwha XE20
    By THPP in forum RFQ (Request for Quote)
    Last Post: 02-23-2017, 02:08 AM
  2. Replies: 2
    Last Post: 01-16-2016, 03:23 AM
  3. Replies: 10
    Last Post: 04-12-2014, 04:03 PM
  4. converting CT Scans [ dicom files] to cutting files
    By fiddlemakermike in forum WoodWorking Topics
    Last Post: 05-09-2013, 02:15 AM
  5. editing in converted pro/e files to inventor
    By pst in forum Mechanical Calculations/Engineering Design
    Last Post: 07-15-2009, 07:57 AM
