586,058 active members*
4,716 visitors online*
IndustryArena Forum > Manufacturing Processes > Drilling > Instruction multi- head combination Driling machine
Results 1 to 1 of 1
    main feature
    It is used for drilling holes of aluminum and curtain - wall profiles ,as well as drilling assembling holes of aluminum and pVC window and door
    Adopt Programmable (PLC)ensures the machine runninng steady and reliable
    the drilling
    The drilling head can be used individually or jointly as well as be combined at will
    the section of profile is not more than 250 x 250 mm ,the processing length is up to 5000mm
    the speeed of saw blade infeed is linerity adjusable by gas lignid dammper
    • Power 4x1.5 kw
    • Volage 380v 50HZ
    • speed 1400r/min
    • the hose diameter 13mm
    • Max processing profilesection section size 250X250mm
    • Distance between two drilling hole 300 -5000mm
    • drilling head feed travel 125mm
    • Dimension 6000X1000X1900mm
