586,068 active members*
3,928 visitors online*
IndustryArena Forum > MetalWorking Machines > Novakon > PathPilot on a Novakon Questioin
Page 2 of 3 123
Results 21 to 40 of 45
  1. #21
    May 2017
    18
    Re: PathPilot on a Novakon Questioin
    Thanks for all the help getting PP installed. Everything is working great with the help from Brian. The only problem I have, and it seems minor, is that when I exit out of the PP software it says it's going to shut down the computer - but then it just shows the PP background wallpaper and I manually have to power off the PC. Any solutions to this? It's probably not a big deal but I feel like it's not a great idea to do a hard power down on the PC everytime I want to shut it off.
  2. #22
    Aug 2007
    701
    Quote Originally Posted by rickjamesbrown View Post
    Rick mine doesn’t shut down either - I hit the menu bar and tell Linux to shut down. When I get home from vacation I will look into updating to pp 2.02 and seeing if I can fix the shutdown issue.
  3. #23
    Jan 2016
    386
    My PC would never power down with PP1.9x. Using version 2.x it powers down as expected.
  4. #24
    Jun 2004
    6618
    Same here, though I only have the 2.01 on the lathe.
    Lee
  5. #25
    Apr 2005
    1268
    Wow!
    Here we go again. I installed (successfully) pp1.9 on my pro and am inching towards pp 2.0 (or later). I think I'll buy a separate SSD and use that for my conversion attempt so I can at least, revert back to 1.9 if it proves to be as challenging as last time.
    I'll report for later reference when the attempt is made.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
  6. #26
    Mar 2009
    388
    Quote Originally Posted by bill south View Post
    Wow!
    Bill
    I got 2.0.2 running last night on my servo based Torus. I'll post files.
    Scott...
    Instructional Videos for CNC Guitar Building
    http://www.rmgvideos.com
  7. #27
    Aug 2007
    701
    Quote Originally Posted by sagreen View Post
    Scott...
    Great work Scott! I need to update mine to 2.02
  8. #28
    Apr 2005
    1268
    Thanks for the offer Scott!
    I'll look forward to your post.
    Bill
    billyjack
  9. #29
    Mar 2009
    388
    Bill
    Files posted on separate new thread. No instructions yet. You can mostly follow Bonedoc's instructions. These files are still a work in progress to clean up. I have some commented out lines and other stuff that needs deleted, but these are working so far.
    Scott...
  10. #30
    Apr 2005
    1268
    Thanks Scott!
    B
    billyjack
  11. #31
    Aug 2016
    60
    Scott...
    I tried your files on my Torus Pro Servo machine with 2.0.2. It mostly works, flashing the MESA went fine, I have movement in all 3 axis, but spindle wont turn on. Error is: Invalid RPM Setting, RPM must be between 0 and 0 with this belt setting. I dug around in the novakon_mill_base.ini and the novakon.hal and I saw where the min and max in both Low and High belt positions was correctly set to 250-6000. I'm going to continue to plug away at it, but in the mean time, any ideas?
    Jason
  12. #32
    Oct 2004
    188
    Jason.
    I ran in to that, can not remember what it was. I will remark the and change some things on the hal and INI files I am using now and post them.
    I have my machine set up with out the gear reduction in the axis drives. instead of 10000 counts to a inch, it is now 50800counts to a inch.
    I will try to get them posted tomorrow night
  13. #33
    Aug 2016
    60
    Quote Originally Posted by powerr View Post
    Jason.
    That would be a great help. I can diff the files and figure out what I am missing.
    Jason
  14. #34
    Mar 2009
    388
    Quote Originally Posted by WTFover View Post
    Jason
    I think I recall fighting that at some point in the PathPilot conversion, but im not sure. Just for the heck of it could you change the "High/Low" spindle and try to run your spindle? I'm at work, but there is a button on the PP window that allowed people to select which pulley they had the belt on for a Tormach machine. Each has different RPM min/max. Its possible that they are set for only one of the 2 options (high/low).
    Scott...
  15. #35
    Aug 2016
    60
    OK, so small progress. I was able to bypass the error by issuing S500 in the MDI. It now works and I can manually stop and start the spindle. However, there is a new problem, the spindle rotations are reversed. FWD runs CCW, and Reverse runs CW. I issued an M03 in the MDI and it started running backwards, then stopped and started via the GUI with the buttons and verified consistent behavior. I do remember my system doing this in PathPilot 1.9 as well. I never got around to fixing it (or even using the mill) because I was moving and I am just now getting everything set up again.
  16. #36
    Oct 2004
    188
    Have a look at these, The spindle direction output have been inverted so it goes the correct direction, added a line in the novakon.hal so when a program is running it displays the spindle rpm.
    inverted the axis direction and step output so it matches what the novakon board is expecting.
    sagreen did a great job getting it running so I thank him for that.
    let me know if they don't work. Been doing other modifications and took them out because I am not sure if they are working quite well enough.
    Found that we have access to the second port on the mesa card, so figured why not try to add a MPG. It is working at the moment. and will post the files for it later. you will have to add mux4 and ilowpass to the rtlibs.
  17. #37
    Aug 2016
    60
    Thanks for those, I had to go out of town for business, but will be home Wednesday night and give it a shot then. Also thanks for annotating your changes to the hal file. I'm definitely no developer, but I like to think I can follow along and maybe learn a little something. I'd love to here and see more about your pendant setup.
    Also, I have noticed every once in a great while, when I fire up the machine, and then go to reference the axis' , the homing goes in the wrong direction of travel. If I shut the machine all the way down and bring it back up, everything seems OK. It's not the end of the world, but it's happened at least twice.
  18. #38
    Oct 2004
    188
    Make sure it is not setting on a limit switch when you go to home the machine. I have not figured out why yet but I had to put a large home offset in the z axis because if Z calibrated it first it would not come off the switch. then do x or y and it would move the other direction to try an clear the limit.
  19. #39
    Aug 2016
    60
    So I tried Powerr's files as-is, and the spindle now runs the correct direction, although the speed seems to be 16% off. 500 Commanded, PDB shows 420 actual. Also, all the jog and homing are now completely backwards from what they were before. Over the next few days I am going to try and take parts of both configs and get it to do what I need it to.
  20. #40
    Oct 2004
    188
    Interesting, we both have servo machines I wonder why the different travel directions. In the INI file I changed the direction sign for SCALE to flip my travel directions. had to change HOME_SEARCH_VEL and HOME_LATCH_VEL signs too.
    At the moment I am using 2.1.3 and having a Issue with the tool table getting wiped out with each shutdown of the machine.
Page 2 of 3 123
  1. PathPilot on Novakon Torus Pro
    By sagreen in forum Novakon
    Last Post: 10-09-2018, 10:07 PM
  2. PathPilot 2.0 - Working on Novakon (Pulsar)!!
    By brianbonedoc in forum Novakon
    Last Post: 04-03-2018, 03:07 PM
  3. Novakon w/PathPilot Post Processor
    By bill south in forum BobCad Post Processors
    Last Post: 01-12-2018, 12:39 PM
  4. PathPilot on Novakon
    Last Post: 12-23-2017, 09:25 AM
  5. Tool comp questioin
    By JV58 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-23-2008, 01:08 PM
