586,106 active members*
2,935 visitors online*
Results 1 to 18 of 18
    Dec 2017
    10
    Hss vs solid carbide
    Hi all,
    I’m about to do a heap of reasech and development on race car parts out of alloy.
    What tooling is best for shimmy finishes. Theses parts will need to be spot-on. Majority of parts will be programmed with master cam.
    Allan
    Apr 2004
    5737
    Re: Hss vs solid carbide
    What are "shimmy finishes"? Is that an Australian term? In general, HSS tools can be sharper and cheaper. Solid carbide is stiffer, and less likely to "shimmy" when cutting. They are better for harder, more abrasive materials and hold their edges longer. Various coatings are applied to them which can help their performance with particular alloys.
    Andrew Werby
    Website
    Dec 2017
    10
    My bad, was supposed to be shinny, mirror like finish.
    Should we be using coated hss tools? Or just plane hss tools?
    I’ve mostly worked with high tensile steel. So hss,
    Was never an option.
    Cheers
    Al
    Jan 2018
    4
    Better use solid carbide mills, only uncoated with polished edges.
    Nov 2006
    490
    For steel workpieces you'll see a very noticeable surface finish quality increase with carbide tooling (not to mention the machining time will be quicker too). Naturally it depends on the specifics, but you can achieve EXTREMELY smooth floor-finish surfaces with the proper carbide parameters.
    Dec 2017
    10
    Quote Originally Posted by Ydna View Post
    Thanks for reply, I know about using carbide for Steel.
    I’m machining billet alloy, I need a good finish almost mirror.
    Wondering what tooling to use. I’ve gotton different advice from
    Local tooling suppliers.
    Sep 2004
    148
    Quote Originally Posted by Al4350 View Post
    Try some YG Alu-Power 3 flute endmills. Likely you'll get the results your looking for.
    Jun 2004
    6618
    You did not mention which aluminum alloy or grade. Each different class and series is formulated for certain characteristics.
    Some even in the same series machine totally different from each other. For instance 6061, which is likely the most common type for machining is not difficult to machine and you get good results easily. 6063 on the other hand is gummy and likes to throw burrs. It too can be machined, but you have to really develop the right cutting recipe for and use extremely sharp tools. Once the tool gets a little worn. it is history. It would not be a candidate for shinny finishes.
    As for mirror finishes, I doubt you will see that straight off the machine. It would likely need to be polished afterward.
    Lee
    Mar 2010
    1852
    With steel it is sometimes more dependent of the steel for the finish. Many steels with cut nice, but tear. Meaning that the metal removed will bring little chunks of the finish metal with the chip. For great finishes the ones like 4140 prehard have a really nice finish. Over all, the HHS can get a better finish to start, but will dull sooner and machine slower. Probably best to go with carbide.
    What you program with makes no difference at all. Hard to tell you more without more info.
    Jun 2010
    4256
    Hey guys - what is the point of giving suggestions for steel when the OP wants to machine ALLOY? (Which I assume means aluminium alloy given that he is talking about race car parts.) Waste of electrons.
    I suggest using good aluminium-specific HSS cutters with air blast and misting - MQL. Without the air blast you will get recuts which will ding the surface. 2-flute or 4-flute - a good Q. I suggest 2-flute as the larger gap lets the air blast get rid of the chips better.
    But if you want SHINY I think you will still have to polish. Felt disks and rouge.
    Cheers
    Roger
    Good gravy, what a mess this thread is.
    Assuming your race car will use 6061-t6, which is the most common alloy for race car parts (at least the ones I make), flute count and chip evacuation and cooling will be your first concern. 2 and 3 flute will be your best bet, they have more space for chips to be removed, that means you get a better finish. I use a lot of 3/8" and 1/2" end mills, I face almost exclusively with a 2" 4 insert (round) face mill. Good high pressure coolant is needed. HSS, carbide, and coated inserts/mills produce great finishes given the right feeds and speeds. Carbide and coated end mills tend to cut a bit faster.
    Like Lee and Roger mentioned, a true mirror like finish is going to be tough without some polishing.
    Mar 2010
    1852
    Here aluminum is generally not referred to as ALLOY.
    Jun 2004
    6618
    Here everything is an alloy.
    Lee
    It's Aluminum Alloy. North Americans shorten it to Aluminum, Australians shorten it to Alloy. They are both referring to the same thing. Pure aluminum has rather poor mechanical properties, as a result it is assumed that shortened "alloy" and "aluminum" monikers both refer to Aluminum Alloy.
    Mar 2010
    1852
    For a great finish it is hard to beat the Alu-Power endmills. Super nice finish. They are center cutting too, but I would not do a whole lot of plunging without some side movement, as they tend to load up. But, for finish, they are great. The are also very reasonably priced on eBay.
    https://www.ebay.com/itm/5-Pcs-1-2-Y...72.m2749.l2649
    Mike
    Dec 2017
    34
    I will second the Alu-power end mills. They work great, at a great price.
    You will be looking for high helix high positive cutting edge with only 2-3 flutes.
    They polish the carbide to keep the material from sticking to the end mill. This is, I think, the key to a good finish.
    http://www.heavymetalcnc.com
    Jun 2010
    4256
    Agree - it's the polished or honed finish on the cutter which helps a lot.
    Cheers
    Roger
    Oct 2019
    OP never confirmed that Alloy meant aluminum, but if thats the case a 3 flute with a ZRN coating is definitely the way to go. Good chip evac and the coating will give extra life to the carbide by increasing the lubricity against the aluminum. Something like this would be a monster in your ALLOY ; )
    https://titancuttingtools.com/order/...em?itn=TC65932
  1. Replies: 1
    Last Post: 11-22-2013, 01:56 PM
  2. solid carbide drills
    By rags in forum MetalWork Discussion
    Last Post: 09-07-2008, 06:08 AM
