586,477 active members*
3,771 visitors online*
    Feb 2018
    Question Mazak 302 alarm check in line filter HELP!!!
    We have a Intergrex I-200 s with an nuisance alarm. The alarm is a 302 check in line filter. I have contacted Tech support on this issue and they could not tell me what filter the alarm is asking me to check . I have check and/or changed the coolant filter ,hydraulic filter , and the air filter.the coolant filter is cleaned every Monday. The alarm comes up randomly, but seems to happen more when the operators are just getting started running. All the filter are changed and/or cleaned per Mazak recommended pm schedule. We have also checked the coolant tank and cleaned it . All the Mazak alarm manual tells you to do is check the filter, but it does not give you a location nor a hint on what filter. It does not shut down the machine and it will clear out with reset.
    Jun 2012
    36
    Quote Originally Posted by TCollier View Post
    Please check maitenance check data
  1. Mazak PFH-5800 Daikin Oil filter
    By dgutosky in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-08-2017, 11:38 PM
  2. Need to install line filter
    By woffler in forum CNC Machine Related Electronics
    Last Post: 03-04-2010, 11:45 PM
  3. Do I need a need a line filter with my spindle?
    By landmark in forum DIY CNC Router Table Machines
    Last Post: 11-10-2009, 02:42 AM
  4. *NEWBIE* Power Line filter (Transformer vs. Filter)
    By cjchands in forum CNC Machine Related Electronics
    Last Post: 09-26-2009, 02:36 AM
  5. Mazak SQT 200 Hydraulic Filter Help
    By Mark18969 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-26-2009, 12:56 PM
