586,036 active members*
3,654 visitors online*
Results 1 to 10 of 10
    Feb 2018
    : ( New laser is speckling or dotting my work piece.
    I recently purchased a BOSS L1416. Been using a Logilase for a couple years now so I'm not a newbie. I've checked the machine over to make sure it's set up correctly and such. When I laser acrylic or metal marking paint I am seeing that the beam is producing some kind of speckling... as if it's "over-spraying" so to speak. I have never seen this before. Boss has been great with their responsiveness, and said it was a lens issue, so they sent me a new one. I installed it, made sure everything is clean including mirrors. Same problem. What gives! Also, the DPI/scan gap doesn't look quite up to what it should be... 0.05 Having trouble getting it to frost the acrylic.
    Aug 2016
    119
    Re: : ( New laser is speckling or dotting my work piece.
    Any damage to any of the mirrors? I've never seen that sort of shotgun effect on any laser I've used regardless of lens condition. And I've used some extremely crappy lenses lol.
    Mar 2007
    113
    The laser beam may be hitting the air cone hole. I had double images on acrylic and I had to drill mine air cone some. Just a guess
    Aug 2016
    119
    It could also be a component in the beam path not secured properly. Say..... a mirror that is vibrating during x/y motion or something. If it was the beam clipping the inside of the nozzle the results should be more consistent rather than this random scattering IMHO
    Feb 2018
    Good suggestions. The nozzle hole is quite large on this laser, so I don't imagine it could be that. I checked alignment and such and it all seems to be firing accurately. I cleaned the mirrors. and yes Blackened, I have not seen a lens cause that effect myself either but I figured I'd accept their replacement lens Once I get home, I will take another look at parts to see if there is any vibration or something of that nature, like you mentioned. I can't find this problem being discussed anywhere else on the web.
    Nov 2010
    787
    You better check electricity. Grounding and hv cable.
    Your hv psu might be damaged too. It looks to be unintended laser pulsing, not reflection.
    CNC lasers, constructions, service
    Feb 2018
    So I am still battling issues with this laser. Boss has been very adamant about it being alignment or issues with dirty optics, or just out of focus. But I am no dummy when it comes to lasers as I have been using a machine 5 days a week at work for 2-3 years now. Granted, I have never had to do anything outside of routine maintenance and checking the optics and alignment, so I am unfamiliar with problems that may be caused by components elsewhere in the machine, the psu for instance.
    All the power settings that recommend to me, I have to increase drastically. I am currently having issues getting stainless steel flasks to accept Cermark laser marking spray. They recommended speed 200 and 20 power for my machine, and I had to bump it all the way up to 200 speed 70 power to get a so-so result.
    Dear Sleepymind, its a while ago but did you find a solution to this problem in the end?
    Aug 2014
    24
    Zoom into the project file. If you converted a picture, lets say, JPG, to PNG, or traced a JPG and was not careful, this would happen. Please send me the editable project file I will gladly look at it for you, then if theres an issue, i will fix it and send it back to you. If you do it twice, does the dots happen on the same exact spot? Odds are, the file outputted is programmed to make those dots?
    Trust me, This happened to me many times, when transfering files from Photoshop to PSD to PNG . Corel to Trace Image to RDworks. It depends on the technique used. But anyway, provide the file, and I will take a look for you.
    Hello, Can you repair your fail?
  1. using optical fiber to direct laser light to work piece
    By ftaylor74 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-01-2016, 06:10 PM
  2. work piece level
    By hoggy38 in forum Mach Software (ArtSoft software)
    Last Post: 02-28-2015, 07:18 AM
  3. 3d work piece with different depths
    By LockTech in forum BobCad-Cam
    Last Post: 11-08-2012, 09:25 PM
  4. Work piece size?
    By cgroves in forum SprutCAM
    Last Post: 02-13-2011, 10:22 PM
  5. Cutting a work piece.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 03-20-2007, 07:02 AM
