586,036 active members*
3,663 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Biesse > Biesse .CIX format - adding parameters for X,Y values etc
    Guys,
    I'm trying to write a sort of parametric .CIX file for a Biesse.
    It seems as though you can have lines like this in the GEO & ROUTG sections:
    PARAM,NAME=XE,VALUE=LPX
    How & where would I set the LPX value?
    Thanks in advance,
    Dave
    Feb 2008
    482
    Re: Biesse .CIX format - adding parameters for X,Y values etc
    on my older machines- i would just write it into the code
    ie
    n10 lpx=10 lpy=50
    etc
    so much to learn, so much to pass on.
    Thank you for this. I'll try it out on the .CIX file.
    Apr 2019
    13
    LPX, LPY and LPZ are defined in the first section of the CIX file. This is the size of the part.
    Quote Originally Posted by dwhiteley View Post
    Guys,
    Thanks in advance,
    Dave
  1. correct values of 1420, 1430 parameters
    By dolarpond in forum Parametric Programing
    Last Post: 06-08-2017, 11:56 AM
  2. Replies: 1
    Last Post: 05-07-2017, 05:01 PM
  3. Adding VFD parameters to screen
    By Bartos in forum Screen Layouts, Post Processors & Misc
    Last Post: 05-21-2015, 12:39 PM
  4. Operation parameters default values?
    By Konstantin in forum CamWorks
    Last Post: 09-16-2009, 07:50 PM
  5. Coding tool load values with parameters?
    By mystiks in forum Daewoo/Doosan
    Last Post: 12-31-2007, 06:03 PM
